Sprockets
Falconihlist
Sprockets
#1 Post by Falconihlist » Fri Sep 14, 2012 4:49 pm
What is the best sprocket setup for max mpg. I'm smashing 500 miles a week, and would like to get the fuel bill down a bit.
Black is fastest!
#2 Post by blinkey501 » Fri Sep 14, 2012 4:59 pm
Loads of stops and starts 15/42. loads of cruising 16/42. although it depends on what your speed will be...keep the speed down, no hard excelleration will give better MPG
Falconihlist
#3 Post by Falconihlist » Fri Sep 14, 2012 5:05 pm
Pretty much 20 miles on the M3, 30 on the A303 (dual carriage way). Anywhere between 70 and 80 usually with no dragstrip starts.
Black is fastest!
#4 Post by Kwackerz » Fri Sep 14, 2012 5:10 pm
Put your tp's up by a few PSI..
Falconihlist
#5 Post by Falconihlist » Fri Sep 14, 2012 5:29 pm
I'm running 36 front 42 rear currently.
Black is fastest!
#6 Post by HisNibbs » Fri Sep 14, 2012 6:05 pm
I don't think that the gearing makes much difference to the MPG on the Falco.
With 15/41 more revs and probably was crusing 5 to 10 mph slower ( a good thing :smt002 ) which makes up for the added zing else where. At the spead you suggest the bike will be running more efficiently with 15/41 (16/44) rather than the standard 16/41 which works well if you are crusing around the ton.
Falconihlist
#7 Post by Falconihlist » Fri Sep 14, 2012 6:07 pm
Cheers guys :smt003
Black is fastest!
ReggieGasket
#8 Post by ReggieGasket » Sat Sep 15, 2012 7:35 am
Yes I agree; I did a long commute on mine a year or two ago and I think mpg is more about how you ride. There's a group of drivers in the US who compete for max mpg figures (really). They pump the tyres up super hard and try anything to keep the load low on the engine and keep momentum and not use brakes. I used to get 50mpg from mine, but I had a PC3 then - not sure what I would get now. Get your head down and check brakes not binding. It can get adictive. I had to fill up each ride so I knew exactly what I had used. Slip streaming vans helps too :smt003 .
