Motor cuts out while ticking over , no input to the bars etc, adjusted idle up to nearly 2K still does it. Dash lights etc. all ok, no flicker or reset and will immediately restart.
“Cough” while running at any time.
Motor cuts out when pulling off, sometimes feels like it has gone onto one and may pull through.
Motor still seems to go well most of the time and the problem is rarely felt on the open road where it can be given a little stick.
All occur randomly but more frequently when hot often accompanied by a bit of a bang and when leant over pulling into traffic, focusing moments.
Suspected culprit :
A lot of water has entered the tank recently because the run off was blocked and I didn’t get around to fixing that until these symptoms started.
Tried so far:
Thrashing it;
Drained the tank and thought that had fixed it until 20 miles or so then just the slightest “cough” which has now degenerated to an asthma attack;
Side stand switch cleaned and wiggled around a bit;
Kill switch on and off a couple of times.
Other issues to concider:
Over due a valve check;
Ordered new plugs but will be next week before I get them;
Thoughts appreciated.
