possible leak from oil cooler area.... will be checking out soon as can but
has anyone OR know of an oil cooler kicking about for a falco..... i know early milles will fit??
oil cooler
- scottyni
oil cooler
if you can't ride it....
OR take it too bed...
IT AIN'T WORTH HAVIN...
I'll have a look.
Early millies will sort of fit BUT one of the oil hose connections is in a different place. That means bodging the hose runs with a longer hose. It also means that if you have a skidmarx bellypan, you will need to cut a hole in it to accommodate the hose connection.
