Guru time
- Falconihlist
Guru time
For all the clutch slave gurus out there.
Just fitted another clutch slave. The last time I did this, the bike was supported by the side stand. Fitted new slave to pipes and got the lever to lock solid. Fitted slave to bike, tested for operation.
Question is, should the back wheel spin freely with the clutch lever pulled in with 1st gear selected or is there a certain amount of drag?
Black is fastest!
Re: Guru time
mine does drag when cold (i presume that why it goes clunk the first time i hit first, gear clutch glued together with oil) but its free when hotFalconihlist wrote:For all the clutch slave gurus out there.
red and black v twin
- Falconihlist
- HowardQ
Mine does just the same when on the Ultipro workshop stand, it drags for quite a while when cold.
It also clunks into 1st.
Then again mine is still on the standard clutch jet, but after eight years I've just got used to it.
I think they call it character!
Take a ride on the Dark Side
- Falconihlist
- Falconihlist
