Genuine aprilia tank bag
Can any of you original aprilia tank bag owners tell me, how easy is it to fill the tank with one of these on. As you know with the baglux ones you just unclip one end of the bag and lift it up.
I don't want to hunt down an aprilia tank bag only to find you have to take the whole thing off to fuel up.
easy
the forward mount, on the triple crown, stays in place
then slacken off one of the two rear straps - the bag will then slide so you can fill up
then close the tank, reattach the hook and then tighten the strap - simples!
- slickliner6
Talking of one of these,,, does anyone have a spare or know where I can get one ???Aladinsaneuk wrote:
- slickliner6
just called 3 different aprilia dealers and i cant buy one separately bbboooooslickliner6 wrote:Talking of one of these,,, does anyone have a spare or know where I can get one ???Aladinsaneuk wrote:
- slickliner6
oohhh mate,that would be great...only one small problem.....wayno wrote:What does it look like? I might be able to knock something up on the lathe
i have no idea what it looks like.pmsl
anyone got one to take a pic for us?????
ok slick
pop down tomorrow and i will show you a work around... you will be amazed at how easy it is....
(Rawl Bolts are cool.....)
(PM me your mobile number or land line and i will give you a call for address etc)
- slickliner6
cheers for the invite mate but im going offshore tomorrow early morning.But i'll deffo take a rain check if thats okAladinsaneuk wrote:ok slick
ok
i will try and describe the original work around i did untill i bought one
in the top trriple there is a nice 14mm hole - you use it btw to take the top triple off - but, thats where we the tank bag connects too. The official apriilia part is a dinky little black plastic part, but as a work around....
head to B&Q or similar and by a rawl bolt that will fit into the hole. Also buy a longer bolt than the one that comes with the rawl bolt - you are also going to need a washer and a nut. Thread the washer on to the bolt and then apply the nut - this is what stops the strap on the bag from sliding off. Now postition the rawl bolt into the hole so it is just touching - use a set of snipe nose pliers so it does not move and then tighten the bolt in untill it locks
simples
simples
- slickliner6
great idea mate,never thought of that(hell im only an engineer what did you expect)pmslAladinsaneuk wrote:ok
simples
thats one to try when i get home
