Clutch fluid leak ?
Tonyunn
Clutch fluid leak ?
#1 Post by Tonyunn » Tue Aug 14, 2012 7:01 am
Since I got the bike I have noticed a small leak of what I thought was oil on the left hand side of the bike, I now believe it is clutch fluid weeping from the slave cylinder.
So I need to ask is replacing the cylinder easy enough, does it ease the use of the clutch if I fit a Oberon or Factory Racing type and is it easy enough to bleed out the system afterwards.
Speed Blue SL 1000 Falco
Falconihlist
#2 Post by Falconihlist » Tue Aug 14, 2012 7:58 am
It is quite a simple job, you shouldn't have any problems with it. I went for a new OEM seal, and the difference was quite a bit, but haven't tried the Oberon one yet. There will be a few who have them that will comment on the difference in due course.
Black is fastest!
#3 Post by Aladinsaneuk » Tue Aug 14, 2012 1:06 pm
cheapest solution is to replace the seal
search here - i think a part was sourced for not a lot of dosh
READ kzmille's guide to bleeding the hydraulics - its in the aprilia tech section - makes life a lot easier
I would suggest that if you are going to change the slave, get an after market one - I rate the MotoPike and Oberon versions. The MPL is a pain - great when it works but try and get them serviced....
Falconihlist
#4 Post by Falconihlist » Tue Aug 14, 2012 1:16 pm
There is also the factory racing version, but I don't recall seeing any writeups on it. Then again, I may need glasses :smt017
http://www.factorycomponents.com/shop/i ... =68_95_101
Black is fastest!
wayofthedarkhand
#5 Post by wayofthedarkhand » Tue Aug 14, 2012 5:05 pm
The ones from motopike are factory racing and are £84 at the moment too.
Do they new slaves need a new gasket where they mate to the crankcase?
#6 Post by Aladinsaneuk » Tue Aug 14, 2012 5:21 pm
no they do not
GregD-UK
Clutch...
#7 Post by GregD-UK » Tue Aug 14, 2012 10:10 pm
Just fitted a Motopike one, got mine in auction for £63 all in. Easy to bleed, recommend fitting a hel line while you at it and on the top of the line fit a bleed nipple :smt002
Tonyunn
#8 Post by Tonyunn » Wed Aug 15, 2012 7:03 am
I take it there is no bleed nipple already as part of the system then?
wayofthedarkhand
#9 Post by wayofthedarkhand » Wed Aug 15, 2012 8:40 am
Tonyunn wrote:I take it there is no bleed nipple already as part of the system then?
That's clever of them. How do they expect it to be bled without a nipple?
#10 Post by D-Rider » Wed Aug 15, 2012 5:40 pm
There is a bleed nipple at the slave. Life is a whole lot easier if you fit one at the master cylinder too .... as air bubbles tend to rise. Banjo bolt with bleed nipple is what you want.
wayofthedarkhand
Re: Clutch...
#11 Post by wayofthedarkhand » Mon Aug 20, 2012 7:21 am
GregD-UK wrote:Hi all,
For that I guess you need an in-line bleed nipple. Where did you get one of those?
#12 Post by Aladinsaneuk » Mon Aug 20, 2012 8:01 am
with respect to my learned colleagues
READ THE BLEEDING GUIDE FROM KZMILLE
https://www.ridersite.com/viewtopic.php?t=3763
if you follow that then you do not need a bleed nipple at the master cylinder....
#13 Post by mangocrazy » Mon Aug 20, 2012 8:01 pm
With respect to KZMille, it is certainly possible to do it in the way he describes, and if the procedure is followed to the letter it will work.
BUT.
It's a damn sight easier with a bleedable banjo bolt (also known as a bleed nipple banjo bolt), will take less time and is a lot less faff.
It's also worth noting that the later RSVs with radial master cylinders have one built in. Which is nice.
#14 Post by Aladinsaneuk » Mon Aug 20, 2012 8:08 pm
lord yes graham
BUT
it is possible with out it - and i think the real key is to reverse bleed
#15 Post by D-Rider » Mon Aug 20, 2012 9:33 pm
.... but for the price of a banjo with a bleed nipple and the ease it gives to doing the job - and makes a better job of it ......
(and yes, I have bled them without and made a good job of it but can see no good reason not to fit one due to all the reasons above)
