Oil change and Oil site tube
Ianh5
#1 Post by Ianh5 » Tue Apr 10, 2007 7:43 pm
Any body help.
Just changed the oil and filter today, first time I have done it on this bike. Put in the recomended amount, about 3.8 ltrs I think. Ran the bike, on tick over, up to 96 deg, no oil in the site tube. Will this appear if I take it for a spin or is there a problem. I don't really want to put any more oil in until I get you guys opinions.
Ta very much in advance.
#2 Post by Aladinsaneuk » Tue Apr 10, 2007 7:48 pm
pretty certain that you have to let the engine idle for 15 to 20 minutes, stop engine, keep bike level on ground and then look at sight glass
(May need a friend to look or hold the bike up LOL)
difference between min and max is around .45 of a litre btw
Moose
#3 Post by Moose » Tue Apr 10, 2007 7:59 pm
Hi
I changed my oil (about 3.8Lts) last weekend but oil was in the tube.
Did your oil pressure light go out? I take it, it did or you wouldn't have run it for so long. :smt053
It does state in the manual to take it for a 10 mile run, I don't know if this is to move the oil right through the engine under load or if this would sort your problem?
Sorry I can't be of more/any help
Moose
I await I more Experienced Falconeers views :smt023
xrphil
#4 Post by xrphil » Tue Apr 10, 2007 9:02 pm
did mine last fri, and found that it took all 4 ltr, ran it till the fans came on, so hot enough.
I was surprised, but i did make a big effort to clear all the old oil and quite a bit more came out by moving the bike around and waiting a while, comes up about a third of the way up the tube when cold, so may have overfilled slightly but not by much.
#5 Post by fastasfcuk » Tue Apr 10, 2007 9:18 pm
you'll know if you've put to much in it will be in the air box.
John1000
#6 Post by John1000 » Tue Apr 10, 2007 9:44 pm
The black art of the oil change. :smt017
Don’t panic to much I’ve had the puzzle of the disappearing oil too and if bye magic it reappeared.
Gtrain
#7 Post by Gtrain » Wed Apr 11, 2007 6:28 am
I had the problem of the disappearing oil before, when the bike had sat for a while, did get a bit nervous about where it could be so I asked the Aprilia rep and he said its happens because of the dry sump.
Seems that sometimes the oil galleys are open when you shut the motor off so all the oil drains into the sump tank (no sign of oil in sight tube)
and to get it back out you need to ride it, idling doesn't work, bike needs to be moving to get it up.
As for amount of oil 3.8 lt is all you need anymore and your airbox is full of all, good trick is to put 3 and a half litres in, take it for a ride then top up oil after woulds
The problem with common sense is, its not very common
Falcoholic
#8 Post by Falcoholic » Wed Apr 11, 2007 8:15 am
fastasfcuk wrote:you'll know if you've put to much in it will be in the air box.
Or all over the chain!! :smt006
The Delicate Sound of Thunder
Ianh5
#9 Post by Ianh5 » Wed Apr 11, 2007 9:46 am
Cheers guys, I am probably just a worry guts, gonna take her for a blast in a minute so we will see.
