Gear change lever
Falconihlist
Gear change lever
#1 Post by Falconihlist » Sun Aug 05, 2012 2:57 pm
Does anyone know what size bearing goes into the gear change foot lever? Got quite a bit of slop in there, so want to get it swapped out. Cheers troops.
Black is fastest!
Re: Gear change lever
#2 Post by D-Rider » Sun Aug 05, 2012 8:26 pm
Falconihlist wrote:Does anyone know what size bearing goes into the gear change foot lever? Got quite a bit of slop in there, so want to get it swapped out. Cheers troops.
If you mean where the lever pivots on the foot peg support, it's just a plain bearing.
They often need cleaning up and re greasing .... but if you've got slop in there, that's a different kettle of trout.
Falconihlist
#3 Post by Falconihlist » Sun Aug 05, 2012 8:57 pm
yeah, a bit more than slop in there. Probably got 3-5mm lateral movement in it. Going to get some washers in there temporarily until the idiots at the lottery get round to actually drawing my numbers (useless barstewards) and I can get a set off Griff.
Black is fastest!
Falconihlist
#4 Post by Falconihlist » Sun Aug 05, 2012 8:58 pm
Either that, or get the Mille lever on and start doing unexpected up shifts! :smt017
Black is fastest!
slickliner6
#5 Post by slickliner6 » Sun Aug 05, 2012 10:16 pm
Falconihlist wrote:yeah, a bit more than slop in there. Probably got 3-5mm lateral movement in it.
Had something similar on mine,wasnt till i looked closer and found the nut on the back had vibrated loose....... DOH..... :smt009 :smt102
we were so poor when i was growing up.Dad said "its a good job i was born a boy,at least id have something to play with" ;-)
#6 Post by Falcopops » Mon Aug 06, 2012 1:46 am
This has just been discussed on the other side of the pond, have a quick search it was pretty difinitive
