Brembo caliper bolts (not mounting, but caliper joining)
wayno
#1 Post by wayno » Tue Jul 31, 2012 2:10 pm
Does anyone know where to source the bolts that hold the 2 halves of the calipers together? Mine look like they have been stored in salt, presumably due to wheel cleaner.
I read the thread in technical about service kits and have some seals on order (just in case), but I want to replace the bolts while I have them split. I don't really want to use normal stainless cap heads, partly because I like the gold coating and partly because I don't like how far the heads stick out.
I need a set for the rear too. And if anyone can give me the rear caliper seal numbers that would be great too.
mickt1964
#2 Post by mickt1964 » Tue Jul 31, 2012 4:39 pm
wayno
#3 Post by wayno » Tue Jul 31, 2012 7:53 pm
The pro bolt link doesn't seem to work. Thanks for the other one though, I was looking at those type after I posted the question
Re: Brembo caliper bolts (not mounting, but caliper joining)
#4 Post by mangocrazy » Tue Jul 31, 2012 8:21 pm
wayno wrote:Does anyone know where to source the bolts that hold the 2 halves of the calipers together? Mine look like they have been stored in salt, presumably due to wheel cleaner.
If you want the gold/yellow coating, the finish is called 'passivated'. You want high tensile steel, at least 8.8. I bought some when I renovated a set of calipers a couple of years ago, but can't remember where I got them from.
Personally I quite like the look of stainless, but if you're going for that, get the version of stainless that is equivalent to 8.8 - I think its A4-80 (not totally sure about that).
#5 Post by Aladinsaneuk » Tue Jul 31, 2012 8:34 pm
ask nooj
davebms
#6 Post by davebms » Tue Jul 31, 2012 8:39 pm
Aladinsaneuk wrote:ask nooj
yes thats where i got mine from no probs with them
red and black v twin
Falconihlist
#7 Post by Falconihlist » Wed Aug 01, 2012 5:14 pm
dito, but they can be a right twat to get the old ones out!
Black is fastest!
#8 Post by mangocrazy » Wed Aug 01, 2012 5:42 pm
Falconihlist wrote:dito, but they can be a right twat to get the old ones out!
Agreed - I've had to drill some out in the past.
#9 Post by DavShill » Thu Aug 02, 2012 10:44 am
What Alad sez - see Nooj but he's his hols just now.
wayno
#10 Post by wayno » Fri Aug 03, 2012 9:42 am
It's ok, I found some stainless ones. if anyone else needs some let me know as the more you buy, the cheaper they get.
bigun
AP RS Legend
#11 Post by bigun » Fri Aug 03, 2012 12:25 pm
Any more info Wayno? Could do with sorting out my Mille. It's sat outside while I build a garage on my house so looking a little in need of some tlc!
Bigun
wayno
#12 Post by wayno » Fri Aug 03, 2012 1:01 pm
They're just a std M8 x 40 cap head with a shallow cap on it.
davebms
#13 Post by davebms » Fri Aug 03, 2012 2:34 pm
wayno wrote:They're just a std M8 x 40 cap head with a shallow cap on it.
i dont think its that simple :smt017 they have to be the correct grade
wayno
#14 Post by wayno » Fri Aug 03, 2012 3:45 pm
As mangocrazy said, they need ot be A4 80 grade, you shouldn't use anything else (stainless wise) on brake components.
