Power commander 1 and power commander 3 differences
wayno
#1 Post by wayno » Mon Jul 23, 2012 10:48 am
I found out at the weekend that the power commander I've been offered is a power commander 1 so not USB. This isn't too much of a problem as the guy who has it has an old laptop that suits it.
However I wanted to check whether the maps would be compatible between the two units or did they change them internally?
Anyone know?
#2 Post by D-Rider » Mon Jul 23, 2012 11:15 am
Dynojet used to have a good description of all of the types of Power Commander on their website.
Unfortunately it no longer seems to be there.
Fortunately the Internet Archive has grabbed it for posterity - albeit without pics.
http://web.archive.org/web/200807061250 ... rsions.htm
TBH I've never heard of anyone running a PC1 on a Falco
#3 Post by flatlander » Mon Jul 23, 2012 1:53 pm
you probably don't need an old laptop just a converter if it is serial to USB
wayofthedarkhand
#4 Post by wayofthedarkhand » Mon Jul 23, 2012 2:36 pm
The older power commander doesn't allow for as fine adjustment as the newer one can apply changes ever 250rpm (or is it 500) vs every 500 rpm (or 1000, I can't remember), or something to that effect.
wayno
#5 Post by wayno » Tue Jul 24, 2012 7:51 am
I decided to go and physically have a look at this power commander that was causing all the trouble last night, it turns out it is a power commander 3, just one of the original ones. I'm not sure where he got the idea it was a PC1.
So problem solved, Once I've sorted some cans out I'll be sticking that on there along with a K&N.
