I'm back !
redfalco
I'm back !
#1 Post by redfalco » Mon Apr 09, 2007 10:34 pm
I'm back and need help.
Has anybody had problem's with thier Falco, where it cuts out as if your out of fuel. But when you go to re-start it, it seem's to flood, coughs bangs. And when it does start, sometimes cuts out again.
Any help or advice would be greatfully recieved.
#2 Post by Gio » Tue Apr 10, 2007 8:41 am
Lo Redfalco, I'm a newbie on a Falco (bought F9's)
Sorry can't help, engines are black magic to me :smt012
Gtrain
#3 Post by Gtrain » Tue Apr 10, 2007 11:56 am
Hello Redfalco, I don't have that much experience with the aprilias motor and fuel injection, but think your fuels to rich, I would first pop the tank up and check out the filter and if its had the restrictor taken out then check the balance of the throttle bodies
can you tell us some more about the bike, what pipes you running do you know if it been derestricted, does it have a different eprom chip in it, is this a new problem, new bike to you?
hate to answer a question with more questions, but better to start with the easy stuff.
The problem with common sense is, its not very common
FlyingKiwi
#4 Post by FlyingKiwi » Tue Apr 10, 2007 12:07 pm
Hi ya, Have you checked your:
A. Tip Over switch
B. Kill Switch
C. Sidestand switch
FK
redfalco
#5 Post by redfalco » Tue Apr 10, 2007 8:29 pm
Thank's Gtrain. As from previous site, the state of tune is as follow's.
1 Evo air kit
2 Scopion race can's
3 Power comander.
All set up on a dyno.
Its got new plugs and leads.
All ran sweet up until recently.
A change of plug's used to cure the problem, but not no more.
Any thought's are welcome, Skeggy in 2 weeks, any one else going ?
falcomunky
#6 Post by falcomunky » Tue Apr 10, 2007 9:03 pm
Choke cable sticking or trapped somehow?
Bad fuel at last fill-up?
Diesel in at last fill-up??? :smt002
Two is the magic number... ;)
Falcoholic
#7 Post by Falcoholic » Wed Apr 11, 2007 10:20 am
Oi Firestarter!
Choke cable? :smt017
Don't you mean the fast idle cable? :smt098
:smt002 :smt003
The Delicate Sound of Thunder
Gtrain
#8 Post by Gtrain » Wed Apr 11, 2007 12:17 pm
does sound like its running to rich, especially if new plugs used to fix it.
when you changed the plugs were they fouled up, could be theres a problem with your leads, check to see if there all connected properly, if ones not that could be all it is
Thumper
Re: I'm back !
#9 Post by Thumper » Wed Apr 11, 2007 10:04 pm
redfalco wrote:I'm back and need help.
Sounds like you are flooding the engine, don't play with the throttle use the fast idle only.
Always expect the unexpected
Firestarter
Twisted Firestarter
#10 Post by Firestarter » Thu Apr 12, 2007 8:58 pm
Falcoholic wrote:Oi Firestarter!
:smt002 :smt003
WTF have I got to do with it? Don't you mean Falcomunky? :smt098
:smt003 :smt002
falcomunky
#11 Post by falcomunky » Fri Apr 13, 2007 5:36 am
:smt005 Was using Olde English jargon and then somehow managed to slip into 'Firestarter' mode as well!!! :smt005
