Minor Oil Leak
- DavShill
Minor Oil Leak
Just been for a blast and parked up and noticed a small drip of oil on the garage floor. Further investigation revealed oil splash on the exhaust pipework on RHS just below the coolant expansion tank. Looked closer and I think it's coming from the sensor which I am assuming is the oil pressure sensor. Wiped it clean and there is no seepage when the engine is not running so I'm presuming it's only when the oil is under pressure.
It doesn't seem to be leaking from the point where it bolts into the engine, but from where the electric spade connector fits into the body of the sensor.
So - anyone else had this? I presume it's a straight swap out. Timely really cos I need to do an oil change anyway.
- flatlander
Inno skipper mine seems to be using more oil but buggered if I can see where from at least you've found yours lol
- anzacinexile
- flatlander
okay Ill steal this thread then :) suggestions for where my oil is going I think I occasionally notice a seepage on the front left casing as if it is coming from under the fairing not from the oil filler cap itself or anything but it is getting a little concerning
Sometimes the front cam cover seal develops a leak around where the sensor wire passes through.flatlander wrote:okay Ill steal this thread then :) suggestions for where my oil is going I think I occasionally notice a seepage on the front left casing as if it is coming from under the fairing not from the oil filler cap itself or anything but it is getting a little concerning
From where you say you are seeing the oil, it wouldn't surprise me if this was the source - particularly as it's not that easy to get a look at.
- flatlander
Sorted thanks for the input forgot when we put the renegade on didn't put breather filter
Which reminds me.... I really do have to get my shock absorber repaired before summer arrives.k1w1boy wrote:...I've had the oil pressure sensor fail, but most recent oil leak turned out to be from my rear shock absorber.
