Venturi effect ??????
- flatlander
Does this exist ? It came up in a pub bine club the other day and to be honest it's not something I am familiar with or really understand but was wondering if it exists and if so how if at all it would relate to our bikes?
My understanding and yes I was sober :) is that it is some physics thing to do with transfer of greater volumes as opposed to transfer of lesser volume more quickly? Like air and fuel under pressure for example ?
Of course it does .... though your description's wrong.
Here's some info for you:
http://en.wikipedia.org/wiki/Venturi_effect
- slickliner6
we use this a lot on offshore installations.
when a gas well had depleted we put in smaller tubing string which in turn encourages the venturi effect.(and yes .. it does work)
- randomsquid
- Wear the Fox Hat
- flatlander
A is that good for us bronzed Adonis type folks then ?
Squid squid we got something right !! Not only do they look better ....
- randomsquid
- Wear the Fox Hat
- flatlander
right so I have read the wiki article as best as I can understand it and as I understand the comments herein the stuff that always gets said about the black and red having bigger snorkels and therefore being faster would appear to not be correct... (I understood Squids summary better tan wiki) so as I have the potentially faster smaller snorkels is there an optimium size to which they should be shrunk or should I just be glad that I have the slimmer faster ones
It's not in the least bit relevant to the snorkels - just as there is no evidence that the the snorkel design of the earlier bikes is better than the later bikes.flatlander wrote:right so I have read the wiki article as best as I can understand it and as I understand the comments herein the stuff that always gets said about the black and red having bigger snorkels and therefore being faster would appear to not be correct... (I understood Squids summary better tan wiki) so as I have the potentially faster smaller snorkels is there an optimium size to which they should be shrunk or should I just be glad that I have the slimmer faster ones
http://www.bikeboy.org/aprillia03rsvr.html
Rene used to play with the trumpets too with an effect on power delivery.. better maybe not, but trumpet height will alter things
or are you on about your inlets from the front of the bike? in which case RiOT ran witty's bike with big fk off bits of rubber inlet hose probably 60mm diameter, which also worked to improve things
That, is a classic..
Looks that way, later bike = whooshier air.
