oil in the airbox
struv
oil in the airbox
#1 Post by struv » Sat Jul 07, 2012 6:18 pm
slight amount of oil in the airbox when i looked today iv only recently bought the bike and have noticed when warm it smells oily sort of smell my pajero makes when its got a weep from the rocker cover .so i opend the airbox to find a clean filter but a film of oil on the base of the airbox and on the offside where theres a low part to the plastick casing there was about a half teaspoon of oil .is this normal the bikes only done 16k and seams to run well in all other ways and i cant remember if my last falco was like this as it was 10 years ago :smt017
davebms
#2 Post by davebms » Sat Jul 07, 2012 6:45 pm
mine does it some times, normally if i top it up a bit to much i think there is a pipe with a bung in it to drain of exes oil at service intervals
so don't worry about it
dave
red and black v twin
roosterNI
#3 Post by roosterNI » Sat Jul 07, 2012 6:47 pm
dont worry about a little oil in the airbox, mine has always done it. but it does sound like you maybe have a little leak thats burning off on the exhaust.
#4 Post by fatboy » Sat Jul 07, 2012 7:30 pm
Engine breather goes into the airbox............
normal to find some oil in there, now if you found a spark plug ???
#5 Post by blinkey501 » Sat Jul 07, 2012 7:40 pm
Its normal, chill dude your bike is fine :smt023
struv
#6 Post by struv » Sat Jul 07, 2012 7:45 pm
cheers put my mind at rest .now is it normal for it to rain everytime i get a day off work :smt102
#7 Post by D-Rider » Sat Jul 07, 2012 7:47 pm
It's a special power-enhancing feature. Lubricating the air helps it to flow more quickly through the air-box, down the throttle bodies and past the valves in to the cylinders.
Cunning design :smt002
#8 Post by randomsquid » Sat Jul 07, 2012 8:43 pm
My Falco one generally has a bit of oil in.
The kwak doesn't because all the leaves and dead insects soak it up.
