#76
by mangocrazy » Thu Nov 10, 2011 8:00 pm
blinkey501 wrote:I have posted before that the origional spring is like having a piece of solid bar in place has there is no give in it what so ever.
I concur. Wholeheartedly. In the short while I had the standard shock fitted I was determined to get the seats fitted with gel pads. Any ride over 50 miles was quite literally a PITA. I got the Ohlins with the correct (for me) spring rate, and we did a tour of France in 2010 without any bother. It's still on the standard seats, front and back.
FWIW, if you run standard Falco triangles/dogbones as I do, a spring rate of 700lbs/in works well for me. Nice and taut solo, plush but controlled two-up.
#77
by D-Rider » Thu Nov 10, 2011 8:05 pm
Mine was like a pogo stick - not rock solid but no useful damping
#78
by mangocrazy » Thu Nov 10, 2011 8:08 pm
I think they're piss poor all round. If the spring rate doesn't get you the damping disappears. I was so glad to get shot of it. It must have done all of 500 miles before I took it off.
- Wear the Fox Hat
#79
by randomsquid » Thu Nov 10, 2011 9:53 pm
blinkey501 wrote:
But also i am having a full set of panels painted in a colour scheme that i think will look out standing
Bronze and black or black and bronze?
- Wear the Fox Hat
#80
by randomsquid » Thu Nov 10, 2011 9:56 pm
Eating lots of cake is a sure fire method of getting the back shock to move. Mine generally seems to be going in the opposite direction to my arse though.
#81
by flatlander » Thu Nov 10, 2011 10:18 pm
I think that he is going to make his own Olive or pistachio green one
#82
by blinkey501 » Fri Nov 11, 2011 5:46 am
No john but its not all black either, well the belly pan and hugger will be
. and there will be some gold bling which is nearly bronze
robbier6
#83
by robbier6 » Fri Nov 11, 2011 8:23 am
Having spoken to the vendor, he says and i quote;
"i bought an rsv ohlins and put the white spring on that, this shock as the ohlins spring re-powder coated on it"
Is that any good?
#84
by D-Rider » Fri Nov 11, 2011 9:10 am
robbier6 wrote:Having spoken to the vendor, he says and i quote;
Is that any good?
Pictures? we can then probably tell from what it looks like.
If it really is an ohlins but the spring has been re-coated, that's fine.
Which year bike did it come from? that will dictate which linkages it was designed to use.
robbier6
#85
by robbier6 » Fri Nov 11, 2011 9:34 am
its an early white spring rsv shock, but with the ohlins spring, i will have a go at putting pics up when it arrives
#86
by D-Rider » Fri Nov 11, 2011 9:47 am
Oh now I understand
1) Don't know whether the spring is the right length
2) Don't know whether the spring has the right rate - and depending which year ohlins it's from, it will have a different spring rates
Sorry - I'm not much help here
robbier6
#87
by robbier6 » Fri Nov 11, 2011 11:18 am
well i'll fit it regardless, and if it bounces around like a bouncy castle i'll look for a different spring
Squid, i've already eaten 3 x my body weight in cakes!
- Wear the Fox Hat
#88
by randomsquid » Fri Nov 11, 2011 5:41 pm
I'm intrigued.
With you on the gold bling. My bent tyre valves are gold and very posh they look too.
- Wear the Fox Hat
#89
by randomsquid » Fri Nov 11, 2011 5:43 pm
Good man!
#90
by blinkey501 » Fri Nov 11, 2011 5:47 pm
I'm intrigued.
John you just spoilt my surprise
