Ok so coolant changed using Ken's instructions and it worked a treat... instead of a cobalt blue its now a girly pink
Then I moved onto the forks... I decided that since my seals weren't weeping I'd give the whole fork removal a miss and just drain the oil, again using Ken's instructions (and some more on the Aprilia Forum). The bike was on the Abba stand and the front jacked up under the front exhaust allowing the forks to be fully extended. This is the current setting on the forks before any work was done:
Which is 5 lines preload and 3 lines showing above the yoke. The rebound and compression are both stock (1.5 out and 1.0 out respectively). When I had the bike from Andy the compression was fully in and I found this too harsh. I intend to retain all preload and rebound/compression but will be dropping the forks by one extra ring.
I wound the preload right out and undone the fork caps... this was pretty hard and I did end up scratching the anodised caps a bit, but nothing a bit of TLC won't cure. I then jacked up the front wheel to push the forks up and out of their casing.
At this stage I'm ready to change the oil... I completely wound out the compression and removed the valve using a 14mm wrench... careful to catch all oil with a container. The volume drained from both legs were similar, 430ml for the left fork and 425ml for the right. I let both drain for maybe 10mins and then pumped (gently) each fork to get as much out as I could. Guess what the colour was?
Yup... horrible!
So I cleaned everything up, replaced the compression valves and set the compression to 1 turn out. Now I had three options... either fill up each fork with how much was drained, fill up and measure oil level from top of fork using values suggested by other peeps (e.g. Ken's site and the Aprilia Forum), or just fill up with recommended volumes and not checking. I opted for the following:
1. Fill up the forks with how much oil was drain -10ml
2. Measure the oil level in each fork at four positions and find an average
3. Compare this average value with Ken's suggestion (8cm) and guys on Aprilia Forum (7cm).
And thats pretty much what I did! Here is some fresh oil... 5W Morris oil from Griff... loverly!
Both legs are set exactly to 7cm oil level (that is, the oil level is 7cm below the top of the open fork) and I checked both three times, all values were consistent. I then released the jack from the front tyre to extend the forks, being careful for the fork caps not to catch as they fall down. I tightend the caps, set the preload and rebound to my previous settings and then loosened the yoke bolts to drop the forks. This was well easy, basically jacking up the front wheel again and hitting the top yoke with a rubber mallet to expose one more ring. This is how it is now:
So correct me if I'm wrong... this is four rings showing?
All in all a good day... plus I had breakfast in bed, lots of presents and now a roast and on my second bottle of Vino... being 32 today ain't so bad
