New forum member
Make your first post here!
#61 Post by DavShill » Sun Jun 30, 2013 6:38 pm
Sorry Pete - you are a top bloke honest..... just thought the thread was being hijacked by the usual banter.
#62 Post by Aladinsaneuk » Sun Jun 30, 2013 7:03 pm
Oh lord yes!
Was in danger of being a normal thread....
SL,STEVE
#63 Post by SL,STEVE » Tue Jul 02, 2013 3:39 pm
Hi guys, bike is now in a local bike shop. Not sure what to expect but spoke to one bloke there and he seems to know a bit about italian V twins, not sure if this helps or not though!
Of course you dont look fat on a Falco!
SL,STEVE
#64 Post by SL,STEVE » Sun Jul 07, 2013 8:21 am
Bike is back, as loud and proud as before. All they found apart from the obvious air lock was a perished and cracked link pipe?
#65 Post by Aladinsaneuk » Mon Jul 08, 2013 7:17 am
steve also sent me the list of work done:
Machine collected as requested.
Carried out ECU diagnostics but no faults recorded.
Checked machine to see if is working.
Appears ok as all plugs are firing.
Checked fuelling and pump pressure, varying at random intervals.
Bled fitting on fuel rail and machine now starts and runs.
Test rode but machine not cred and still tries to cut out.
Stripped fuel pump from machine for investigation.
Checked inline fuel filter.
All parts of pump appear to be working as required.
Refitted into tank and checked for leaks. None found.
Checked all throttle body connections and fittings, replaced small section of link pipe that was perished and split.
Rechecked throttle sync and all appears to be fine.
Refitted all removed parts to machine and test rode. All now working as required. Advisory, airbox has several bolts missing.
i suspect that the fuel lines / filter were routinely blown through and cleaned as well
main thing is, it is working :)
#66 Post by Willopotomas » Mon Jul 08, 2013 2:00 pm
Gonna be some bill. Fair bit of work there.
But as you said Pete, it's working. :smt003 :smt003
#67 Post by Aladinsaneuk » Mon Jul 08, 2013 3:08 pm
I was told the bill was 125 - which is I think reasonable - estimating 40 quid an hour for labour and 25 quid for collection
#68 Post by Willopotomas » Mon Jul 08, 2013 3:31 pm
Not bad at all that.
#69 Post by blinkey501 » Mon Jul 08, 2013 4:46 pm
Great news :smt003
SL,STEVE
#70 Post by SL,STEVE » Tue Jul 09, 2013 3:23 pm
Yeah, £125 all in. Collection as it was local was only £10. I am very pleased with the service I received apart from the missing airbox bolts as I told them they were loosely fitted after myself and Pete had a play. I reckon they got her running and took her for a run where a couple of the bolts went awol. But, excellent service all in all and very reasonable. Good to be back on her too :smt007
#71 Post by HowardQ » Tue Jul 09, 2013 4:43 pm
Great that you're up and running again, just enjoy the bike and the weather!
