As I said, the MOT is a different matter.
You will probably get no trouble from MOT chaps or be pulled by Plod.
The thing that may attract Plod to look more closely is if they notice an apparent lack of rear indicators - but it sounds as you will have other indies too.
.... and anyway, how many plod know the rules .... witness the video of the cyclist who jumped the red light .....
Others were asking what the rules are and Paddy couldn't find them - I just posted a link to them and explained my reading of the relevant bits - I wasn't saying that you will have problems and the world will end.
Falco indicators
- HowardQ
I use them with my smoked rear lense and they are fine. Make sure you get some with LEDs that point sideways as well, so they light the reflector panels, otherwise you will only see a light source the size of the bulb itself.anzacinexile wrote:LED's dont have filaments but how they work is the bulb may have 24 LED's but only 25% are used for the rear light and the remaining 75% are used for the brake lightwayofthedarkhand wrote:The LED bulbs that are the same fitments as the standard rear light bulbs - how do they work when braking?
They're rated at around 2.5w, 5w for standard rear, and 21w for the brake lights, which are of cause housed in the same bulb.
Take a ride on the Dark Side
Not seen any that do that (other than my boards). The replacement bulbs I've played with (talking a few years ago now) worked on a voltage difference. All were on for the tail light, then got fractionally brighter with a small voltage increase (bypassing a resistor) for the brake lights. Pretty shit design as it's very hard to make out the change in brightness.anzacinexile wrote:LED's dont have filaments but how they work is the bulb may have 24 LED's but only 25% are used for the rear light and the remaining 75% are used for the brake lightwayofthedarkhand wrote:The LED bulbs that are the same fitments as the standard rear light bulbs - how do they work when braking?
Things have moved on now though with OE car/bike built-in LED arrays, but I don't know how the latest lot of replacement bulbs work.
- furygan man
...and they are still going strong, pretty verstile and easy to do once you work out which wires to connect, and no resistors to worry about. Have ideas for a MkII if i can be bothered!D-Rider wrote: ..... However, the man from Hinckley (furygan man) also made some .....
https://www.ridersite.com/viewtopic.ph ... hlight=led
