Carbon Fibre Falco Tanks
- flatlander
Are you thinking it might save you lugging that petrol can around ? You being from winsford and all you know a bit of accelerant on tap so to speak
- Firestarter
- Twisted Firestarter
Hey guys, did we get an answer to this one when Rich checked the volume the other day?Firestarter wrote:I'm assuming the extra capacity is spread across the whole tank, i.e. we won't get an extra 4 litres (tbc) in reserve, but will likely get a bit extra in reserve and the rest across the rest of the tank?
Not quite sure what you mean but as the extra capacity comes from the tank wall thickness being dramatically thinner, the inner volume increases wherever there is a tank wall. In a particular area in which there are more tank walls , the increase will be proportionally greater in that part.
- Firestarter
- flatlander
Be honest if you can't set fire to something with 21 litres of accelerant no wonder they kicked you out of winsford
Swollen Tank / Carbon Tank.
Hello All, it's been a while since I have been on here but did anyone ever go for the Carbon fuel tank? Was about to take my bird for the annual MOT today. Strong smell of fuel. Investigation located fuel seeping from the joint at the bottom of the fuel tank around the pipes. Hope it's not terminal.
Just wondered if anyone went for the replacement how they got on?
If it's from the seal around the pump, then it's fixable - mine did the same a long time ago
There is a type of instant gasket - ?red - that is not affected my petrol - you need that. You also need to very carefully remove the original gasket and clean out the retaining lip using a soft tool - I used a wooden spatula
Then use a very thin bead of instant gasket then the original rubber one - then reassemble
