Hmmm. Could be a split breather pipe?
The leak comes from one of the breather pipes from the pump base?
Have you read all this post?
https://www.ridersite.com/viewtopic.php?t=12079
possible sprag failure
You can see one of the two breather outlets will have petrol residue in one of the holes on the pump base?robbier6 wrote:thanks Jay, i'll check the internal pipes too, but if you tipped the tank up you could visibly see it run from under the pump![]()
I think the bore size of the pipe is 10mm on the pipes in the tank.?
Cut one and take it to the suppliers to get a nice tight fit.
This job is not a big task, but to cut the breather pipes I used a junior hacksaw blade wrapped in a cloth to protect my fingers
