Could always go for the half-way house and do the front end I guess .... though Mart has said the forks and discs are different so I'm not sure whether that gives any problems with the OZ front wheel.
I think (& I stress 'think') Mille/Falco front wheels are a slightly different width across the centre of the wheel. Also, the Fut's calipers are positioned to suit their slightly smaller (300 mm) discs. So you'd need to change the forks, and/or the yokes, to accommodate your Oz wheel.
RSV Showa forks will fit easily. They're a bit shorter than Fut forks, so they'd lower your front end, which some like.
Fut discs are smaller (300 mm) than those on other models, & the calipers are slightly different - but they seem to work pretty well.
Should you be interested, I've some Showa forks off an early-ish ('00 - '01, I think) Mille, with the calipers, which I'm not going to put on the Fut - project cancelled 'cos I want to fit bar risers.
