#31
by Aladinsaneuk » Thu Jun 13, 2013 8:07 am
i think that it may reassure some, but i have always viewed it as being a factory fitted anti tamper device
having said that most of us are nervous about this kind of thing as we are not used to doing it - so, for piece of mind it may be a good idea!
#32
by D-Rider » Thu Jun 13, 2013 8:51 am
Aladinsaneuk wrote:i think that it may reassure some, but i have always viewed it as being a factory fitted anti tamper device
Nope
It's a belt-and-braces anti-vibration measure
zoidberg
#33
by zoidberg » Thu Jun 13, 2013 9:43 am
D-Rider wrote:Aladinsaneuk wrote:i think that it may reassure some, but i have always viewed it as being a factory fitted anti tamper device
Nope
It says that in the handbook for my sl chip. It doesn't however say what to use.
#34
by D-Rider » Thu Jun 13, 2013 10:35 am
Silicone should be fine
#35
by Viking » Thu Jun 13, 2013 11:18 pm
zoidberg wrote:The glue stuff you put on the chip....what is it?
I have no idea what it is. I presume it was put there by Aprilia.
D-Rider wrote:Looks the same to me - apart from a different sticky label.
Oh haha! You funny man!
I was referring to the label.
Forgive me if the tongue-in-cheek humour does not translate well. I'm not having a good time at the moment.
#36
by D-Rider » Fri Jun 14, 2013 12:40 am
Hope the good times come back in sight, Viking
.... and the tongue in cheek works fine :)
zoidberg
#37
by zoidberg » Fri Jun 21, 2013 8:00 pm
New pins ordered for my chip. I should have it sorted by the middle of next week.
zoidberg
#38
by zoidberg » Mon Jul 01, 2013 3:51 pm
i now have a fully repaired chip. i'll report back when installed
zoidberg
#39
by zoidberg » Tue Jul 02, 2013 1:15 pm
Unsuccessful. I get a fault code -1 when the chip is in and a lot of clicking. That is all
Oh well, a forza chip it'll be then.
#40
by D-Rider » Tue Jul 02, 2013 2:51 pm
-1 is the throttle position sensor reading.
You shouldn't get this unless the diag wires are plugged together - which they shouldn't be.
Where's the clicking from and when do you get it? Is it the starter relay?
- Midnight Rider
#41
by Dalemac » Tue Jul 02, 2013 3:22 pm
zoidberg wrote:Unsuccessful. I get a fault code -1 when the chip is in and a lot of clicking. That is all
Could also be the fuel pump priming when you turn the key?
zoidberg
#42
by zoidberg » Tue Jul 02, 2013 3:24 pm
fuel pump doesn't prime and it goes into diag mode.
clicking from the rear seat area
#43
by D-Rider » Tue Jul 02, 2013 3:29 pm
So .... are the diag wires connected together?
The noise will be the starter relay. Probably needs a new relay but it could be the state of your battery.
zoidberg
#44
by zoidberg » Tue Jul 02, 2013 3:32 pm
the diag wires were not wired together and my battery is fine. as soon as i put the standard PA08 chip back in all was well
#45
by D-Rider » Tue Jul 02, 2013 3:59 pm
OK - external components it isn't !
