That wasn't the question !Dalemac wrote:
to which one!
My falco seems a little ill
control_67 wrote:Isn't it al little dodgy to take one plug out of a two plug head to check? As in the remaining plug could fire the fuel in the cylinder and then you could have a couple of jets of flame coming out of the empty plug holes?
Disconnect the plug leads...
Wouldn't have thought it very likely with no real compression.control_67 wrote:Isn't it al little dodgy to take one plug out of a two plug head to check? As in the remaining plug could fire the fuel in the cylinder and then you could have a couple of jets of flame coming out of the empty plug holes?
Indeed. Although it would have been quite cool (and probably painful) if it did fire up.D-Rider wrote:Wouldn't have thought it very likely with no real compression.control_67 wrote:Isn't it al little dodgy to take one plug out of a two plug head to check? As in the remaining plug could fire the fuel in the cylinder and then you could have a couple of jets of flame coming out of the empty plug holes?
Its all gravy now. Next job - change the front fork oil and look at* getting the rear shock reconditioned.
* - might need a (physical) hand with that.....
