Are RSVR Mille Oz Wheels worth it?
They are worth having and when you are done you can get your money back. So a no brainer really. The thing I noticed was that the bike would stay down when applying the power rather than tending to stand up. Made it easier to hold a line and power out. That and the bike felt "lighter" all round.
I've finally got my Oz wheels powder-coated and ready to fit to the bike, and I've decided to go with a 190/55 Sportsmart rear. The 190/55 gives a useful increase in rear ride height (and turn-in) over the 190/50 (nearly 10mm, actually) and, as Ben points out, a 6" rim is really designed to be used with a 190 section tyre.
Full report once I get my headers back from the welder/platers and this bloody rain goes away...
I wonder how much a 190/55 rear tyre will affect the accuracy of the speedo reading?mangocrazy wrote:I've finally got my Oz wheels powder-coated and ready to fit to the bike, and I've decided to go with a 190/55 Sportsmart rear. The 190/55 gives a useful increase in rear ride height (and turn-in) over the 190/50 (nearly 10mm, actually) and, as Ben points out, a 6" rim is really designed to be used with a 190 section tyre.
Worth being aware that it would tend to make it under-read .... but I'm not sure by how much.
That only works when you actually know the radius. All I know is the difference between respective aspect ratios (5.5mm in this case).HisNibbs wrote:Increace in ride height down to Increace in radius so no meed to measure the circumference. (2*pi*R)
Measuring the circumference is easy, anyway. All you need is some level ground, a piece of chalk and a tape measure.[/list]
