No idea I'm not even a knowledgeable amateur at spotting the difference and if it did how far can you turn it?Goldie wrote:Doesn't the Ohlins shock on your bike (...see I managed not to call it F9's![]()
) have ride height adjustment?
Fitting a New Shape RSV swinger
- Falco9
Gio,Goldie wrote:That's a known issue with that type of bellypan. Only really a problem on trackdays, I believe.Gio wrote:I'd be interested in that purely because with falco9's bike I believe (correct me if I'm wrong Rich) there's an issue with grounding the belly pan on its present setting (3.5 rings showing above the headstock). I'd much rather raise the rear by that amount than drop the forks.
...but with legs like yours you could raise the rear as far as you want!
I have had it grounding out (every so gently) with the current suspension settings. Gareth @ Reactive set the forks and as she handled so well I stuck with the old mantra of "if it ain't broke don't f**k with it"
You may well get an improvement by altering the set up to suit you, in fact I'd be surprised if you didn't as you are considerably lighter than me, and as we all ride differently anyway, we all have a preferred setup
Goldie,
It does have ride height and it's on max extention, and I think your right about the bellypan its just a design flaw. To be fair to Peter (Pifkee) he never designed it for racing, it was purely for looks
F9
Falco9 wrote:Gio,Goldie wrote:That's a known issue with that type of bellypan. Only really a problem on trackdays, I believe.Gio wrote:I'd be interested in that purely because with falco9's bike I believe (correct me if I'm wrong Rich) there's an issue with grounding the belly pan on its present setting (3.5 rings showing above the headstock). I'd much rather raise the rear by that amount than drop the forks.
Goldie,
Okay so going by what you're saying with my weight deficiency over you, resetting the suspension (softer) will cause more of a problem with grounding, is there anyway the bellypan can be modified?
If not what is available that would stop the problem?
on a secondary note what has been altered on the front forks, ie have they been revalved and springs changed?
Sorry for all the questions but I'm sure come Wednesday if I'm asked I'd like to know some answers, cos as you point out we do all ride differently.
F9
- Falco9
Gio,
No your weight won't cause any further problems with grounding the bellypan. Probably the reverse as you haven't as much weight pushing the bike down.
I just think it now has too much preload front & back as you are lighter than me, hence the current settings are probably now causing the skittish feeling you described on an earlier thread.
The forks haven't been resprung but they have been re-valved. After riding the new Tuono today I can assure you my new bike will have the forks re-valved as well. The Falco front end was much better than the Tuono as std
F9
F9
