#25
by MartDude » Tue Jan 03, 2012 1:29 am
Yes, Graham, pre-load & rebound only.
As I said earlier, I have a spare - the grubby one in the pics - if anyone wants to borrow it to experiment, you're welcome.
Within the Futura community, most owners seem to find this shock ok - but some don't rate it very highly. Most of the nay-sayers are Americans; I suspect their view may be in part due to the generally more ample proportions, & concomitant weight, of the US population. Some have found it doesn't hold up too well to extended touring, 2-up with luggage. But, as I said, most find it fine. And remember, the Futura is around 20kg. heavier than the Falco.
Maxton have this to say about it :
The rear of the Futura is too soft. The spring on the unit is sprung for a
round an 8 or 9 stone rider. This makes the bike sit down under power and
run wide out of corners. It also makes the bike hard work to move around
on tight, twist roads. The standard Futura shock absorber does not have
enough rebound or compression damping either. This means there is not
enough support with the spring, and even though the spring is soft, there is
not enough control of the spring. Because of the damping problems, it
means there is very little point in respringing the standard rear shock as it
just becomes a “harder pogostick”. The standard shock absorber is a
sealed unit and cannot be rebuilt. Even if you could find a way to strip
the shock down, you cannot buy any parts from Aprilia for the damper.
To cure the handling problems of the Aprilia Futura we recommend a new
shock absorber.
Well, you wouldn't expect them tp praise it, would you?. I showed this to Griff a while back - he said it's largely bollocks, & the standard unit is fine for most people in most situations.
