PMSLmangocrazy wrote:I reckon the Falco was simply behaving like any woman would when your attention was elsewhere - throwing a hissy fit to get your undivided attention. You've been giving it some attention and things are now OK again...
But then, it could be something electrical...
Falco sprag gear gone? (Video)
- Carlos Von Brum
- Carlos Von Brum
It starts up instantly now, like you would expect a new bike to. When it was playing up, the engine would turn over instantly, but just would not fire. The Diag mode reported everything nominal, I'm hoping it was a loose ground or a bit of water somewhere which will behave itself now...Dalemac wrote:Having just gone through a dead starter relay myself, you may wish to check yours too. When you hit the starter button, does it pause or lag for a second or two before spinning the starter motor, or does the starter spin up instantly?
Dale
Ok sounds like the relay is ok then.Carlos Von Brum wrote:It starts up instantly now, like you would expect a new bike to. When it was playing up, the engine would turn over instantly, but just would not fire. The Diag mode reported everything nominal, I'm hoping it was a loose ground or a bit of water somewhere which will behave itself now...Dalemac wrote:Having just gone through a dead starter relay myself, you may wish to check yours too. When you hit the starter button, does it pause or lag for a second or two before spinning the starter motor, or does the starter spin up instantly?
Dale
I would do what the others have suggested and look at the spark plugs# the fueling.
Dale
Always, if it won't fire, the first thing to try is the "oh-cr@p-I-must have-flooded-it" starting routine.
Hold the throttle wide open and hit the starter. That usually clears things out and it will fire.
If not, then it's probably something else - however as this is so easy to do, it's always worth a try.
Never start like this for a normal start up.
