Any Ideas??
#16 Post by randomsquid » Sun Oct 23, 2011 10:39 pm
MartDude wrote:
randomsquid wrote:Then all you need is a left handed drill.
To go with the left-handed hammer
I've got a special two handed hammer. For really tight screws.
#17 Post by D-Rider » Sun Oct 23, 2011 10:46 pm
Obviously I was wrong .... the simplest way must involve a large number of superconducting magnets to create a contra-rotating field that if tuned to a precise frequency will release the bolt with a left-handed screwing action.
OR YOU COULD GET AN F-ING DREMEL-TYPE-THING, CUT A SLOT IN IT AND UNDO IT WITH A FLAT-BLADE SCREWDRIVER
keithy
#18 Post by keithy » Mon Oct 24, 2011 6:26 am
Did this the other day no need for flux capacitors or even photon torpedos i cut a slot in the bolt head with a dremmel and used a plain screwdriver to remove it was not tight.
Cheers Keith
#19 Post by blinkey501 » Mon Oct 24, 2011 6:37 am
Willopotomas wrote:Had a look.. And ye learn something new every day! Seems they come part of some stud extraction kits.. :smt003
Same hear will i thought it might have been a wind up like a left handed screwdriver :smt003
#20 Post by D-Rider » Mon Oct 24, 2011 7:43 am
keithy wrote:Did this the other day no need for flux capacitors or even photon torpedos i cut a slot in the bolt head with a dremmel and used a plain screwdriver to remove it was not tight.
Cheers Keith
Top idea that - wish I'd thought of it. :smt003
#21 Post by flatlander » Mon Oct 24, 2011 8:26 am
Cheers Keith
Yeah that seems a good starting point if only someone else had thought of it earlier :smt002
Now about my left handed trapped stud do o need a right handed drill and bit or would a neutral one do? :smt003
#22 Post by D-Rider » Mon Oct 24, 2011 8:37 am
flatlander wrote:
Now about my left handed trapped stud .......
.... so in one post he not only "comes out" but admits to imprisoning a sex slave.
Do you have a right handed one as well or is this left handed thing a key part of your world of perversion?
:smt017
#23 Post by flatlander » Mon Oct 24, 2011 8:51 am
Definitely ever since Mrs Gorbet used to chastise me for being a child of Satan for writing left handed
Still she did me a favour really as when I lost the use of my left hand side I was able to switch to to the right ... See something else we may have in common apart from the best coloured Falco :smt008
#24 Post by HowardQ » Mon Oct 24, 2011 12:36 pm
So just to confirm Andy.
If I want to do the same, just where do I get a
left handed F-ING DREMEL-TYPE-THING ??
:smt017 :smt017 :smt017
I already have the dual handed slotted screwdriver, so no problem there!
:smt005
#25 Post by Willopotomas » Mon Oct 24, 2011 4:53 pm
Or. Just as a theory, I don't expect this to be possible. Get one of those Dremel type thingy's, cut a slot in the top and undo it with a flat head screw driver. A left handed one of course. When cutting, don't forget to catch the sparks.. Save up enough and you'll be able to weigh them in down the scrap yard. :smt002
#26 Post by randomsquid » Mon Oct 24, 2011 5:06 pm
Impact driver & lump hammer. It'll make a slot all by itself.
#27 Post by Willopotomas » Mon Oct 24, 2011 5:18 pm
randomsquid wrote:Impact driver & lump hammer. It'll make a slot all by itself.
There we go! Solution found.. :smt003
#28 Post by Aladinsaneuk » Mon Oct 24, 2011 7:58 pm
But would that be a left or right handed impact driver?
Falcorob
#29 Post by Falcorob » Mon Oct 24, 2011 8:07 pm
D-Rider wrote:Obviously I was wrong .... the simplest way must involve a large number of superconducting magnets to create a contra-rotating field that if tuned to a precise frequency will release the bolt with a left-handed screwing action.
I'm going to try this at the weekend if I can find my f-ing dremel-type-thing. :smt003
#30 Post by D-Rider » Mon Oct 24, 2011 10:13 pm
Just as an interesting aside .... well, possibly mildly interesting .... most of you know I work for a Japanese company and have a good number of Japanese friends.
I quite like the Japanese method of referring to the different types of screwdriver:
  • A cross-head screwdriver is a + (or plus) screwdriver
    A flat-blade screwdriver is a - (or minus) screwdriver
Simples
