Wanted ohlins links and dogbone
and there's more
#16 Post by flatlander » Fri Oct 14, 2011 10:30 pm
ok I managed to find out some more though I am not sure whether it is any clearer for that :smt017
Oh and I do appreciate all the help BTW :smt007
Was in the original ad that the guy I bought it off bought it from if you catch my drift lol
I purchased this ohlins shock from the owner of a 2002 RSV mille factory R to fit to my 2004 Tuono, of which both bikes share the same frame and suspension set-up. I have since sold the tuono so i removed the shock and re-fitted the original one. The distance between the mounting holes is 320mm. I believe the ohlins shock was made to fit models: Aprilia RSV mille years 1999-2003, also Aprilia RSV mille tuono years 2002-2005."
I also found this from an old post on some site
02 side plates and dog bone.
http://i4.photobucket.com/albums/y111/m ... G_2088.jpg
distance between centers 130mm
material thickness 10mm
width 36mm
http://i4.photobucket.com/albums/y111/m ... G_2086.jpg
Distance between hole centers as in the photo:
left to top 75mm,right to top 85mm,left to right 60mm
plate thickness 6mm
Width at the thinest point.
left 12mm
right 20mm
bottom 21mm
Not sure that helps or is accurate but at least wanted to show willing in making some effort to find the answer ;)[/img]
#17 Post by Aladinsaneuk » Sat Oct 15, 2011 8:25 am
http://www.apriliaforum.com/forums/show ... p?t=162440
i think that has the answer you need - you need the ohlins triangle and dogbone from a 2001 to 2003 OHLINS mille
#18 Post by D-Rider » Sat Oct 15, 2011 8:36 am
Aladinsaneuk wrote:http://www.apriliaforum.com/forums/show ... p?t=162440
...... which I thought we'd answered many many times on this forum too .....
.... and the mille also has triangles (of the same shape) but different thicknesses. 4mm thick in Steel and 6mm thick in Aluminium - applied to different models (though that doesn't matter as long as you have the bolts of the right length to do them up - as previously mentioned on here too :smt002 )
Falco9
#19 Post by Falco9 » Sat Oct 15, 2011 12:32 pm
The linkages I have are from the later RSV and aren't suitble for you.
However if anyones looking for linkages & Ddgbone from the later RSV I've got 2 sets of em!!!
F9 :smt006
#20 Post by blinkey501 » Sat Oct 15, 2011 4:22 pm
Geoff when i tried to fit your shock, i compared your linkages and shock to mine. You definatly need the ohlins triangles and not your origional ones! Dont get mixed up with what you need :smt002
