Clutch grub screw
Re: Grub Screw...
#16 Post by D-Rider » Tue May 10, 2011 10:23 pm
GregD-UK wrote:Hi all,
Said grub screw it held in by a tiny allen tapered screw, that you can't see, as the allen head is on upside down :smt003 If you remove said lever and turn it 180 Degrees you can then adjust or remove the screw to then adjust the clutch pin which can make a whole lot of difference to how the lever works, trust me on that :smt004
Yes it was actually that allen screw that I couldn't remove - found a key to fit it but it was so tight that the key ripped the allen socket up .....
:smt013
Falco9
Re: Grub Screw...
#17 Post by Falco9 » Wed May 11, 2011 7:29 am
I took the lever off completely and never spotted it, but I'll take it off again and have another look
Good info, much appreciated
F9 :smt006
GregD-UK
Grub Screw...
#18 Post by GregD-UK » Wed May 11, 2011 3:25 pm
No probs F9, DR stupid question, but, did you bestowe a smidge of WD40 or GT45 on the thing... Guess some things haven't been touched on the bike since it was made :smt002
Re: Grub Screw...
#19 Post by D-Rider » Wed May 11, 2011 7:18 pm
No - silly little thing it is, I'd damaged it before I realised it wasn't moving.
Don't care any more - got a radial lever/master-cylinder on there now.
#20 Post by HowardQ » Wed May 18, 2011 12:04 pm
Thanks for pointing this out Rich and later Greg.
Have to have a look at mine this weekend.
Looks like you had a good run out Rich.
Falco9
#21 Post by Falco9 » Wed May 18, 2011 3:33 pm
Hi Howard,
Yes we had a great weekend, thanks
Greg was spot on with this info, although you'll need a tiny allen key to adjust it (1.5mm) the threadlock had done its job for me but the allen key was about one turn loose so I tightened it up as well
I think that grub screw should be in there for ever now :smt003
F9 :smt006
