Scotoiler?
#16 Post by furygan man » Fri Jan 07, 2011 10:45 pm
Interesting and food for thought, thanks all, no doubt when i get it, there will be a cry for help as i prob will get Vacum one but the idea of inserting into a 'vacum' pipe ( :smt017 ??) that i have no idea where it is on the bike scares me somewhat!!!! :smt009
Sorry to labour the point, i'm sure it will be easier when i have the thing in front of me
dyzio
#17 Post by dyzio » Fri Jan 07, 2011 11:08 pm
Second pic in Nooj's thread I've linked earlier
#18 Post by furygan man » Fri Jan 07, 2011 11:28 pm
...got the pics just wanted more detail/clarification...that sprocket cover looks different to the other Millie/Tuono ones I've seen
#19 Post by Willopotomas » Fri Jan 07, 2011 11:52 pm
dyzio wrote:Should work now:
Does this drop oil on top of the chain? If so, you may as well not bother with it. Best place to put the feed is on the sprocket side of the chain so it 'flings' it outward. By dropping oil on the outer side of the chain, it's more likely to just fling off and not reach the underside. Ideally the feed should be mounted so it feeds the chain as it's going round the sprocket, at the link plates on both sides..
A bit difficult to explain it.. You need the oil to fling out through the chain rather than it sit on top and fling off..
confusing meself now :smt017
#20 Post by D-Rider » Fri Jan 07, 2011 11:55 pm
What he said :smt023
#21 Post by Willopotomas » Fri Jan 07, 2011 11:58 pm
also.. feed on to the sprocket close to the chain, but not directly on the chain. :smt002
#22 Post by furygan man » Sat Jan 08, 2011 12:01 am
got that bit, and Andy's version, just need to see Nooj's without the cover on, the pic no.2 where you cut into the hose is a bit too close for me to locate visually on the bike...blimey it's midnight!!!
dyzio
#23 Post by dyzio » Sat Jan 08, 2011 1:01 am
It's on the throttle bodies, LHS as you sit on the bike under the airbox.
You attach a plastic connector onto it (vacuum damper) and run the tubing from it to the reservoir. My damper wouldn't fit so I've heated it up and once it was on, I've secured it with a small jubilee clip.
Some have 2 some have 1, there is an explanation, but I don't know :smt010
#24 Post by D-Rider » Sat Jan 08, 2011 1:19 am
See Here (picture I posted ages ago):
and go to the Scottoiler website and download their instruction guide for the Falco that explains it all
http://www.scottoiler.com/uk/installation-guides.html
as usual, the info is there if you look
dyzio
#25 Post by dyzio » Sat Jan 08, 2011 1:26 am
You think I kept those pics on my desktop? :smt002
Did a few searches today but I didn't come across that particular one.
EDIT:
Eeee, the technical section :smt001
#26 Post by furygan man » Sat Jan 08, 2011 8:55 am
Right getting there now and thanks very much for your patience all, sounds dounting at first but takes a while to get my head around all this, second nature to all you guys i guess :smt023
Dyzio- like your soloution as it covers both Andy and Nooj's ideas
DR- do you have anymore detail than what's in the post for the 'swingarm' bracket for the twin applicator??
#27 Post by Aladinsaneuk » Sat Jan 08, 2011 10:27 am
both andy and i have the mille swing arm fitted - not sure if the falco original has a threaded riv nut in it.....
if it doesn't then one can be fitted :)
#28 Post by D-Rider » Sat Jan 08, 2011 11:02 am
Just let me know what info you want and I'll see what I can recall :smt003
rick
#29 Post by rick » Sat Jan 08, 2011 2:48 pm
I had scottoilers on my other bikes but not the falco... the reason being that I dont commute anymore so have more time for regulat chain maintenance.
Now as some of you may now there is a vacuum pipe coming off one of the TBs that sits above the chain... any ideas how much oil this spits out?
#30 Post by D-Rider » Sat Jan 08, 2011 2:55 pm
errr none ...... :smt017
