Didn't start...could be the Gremlins are back???
- furygan man
- Tweaker
- Main bike: BMW R1250RS
I see you're in West Yorkshire somewhere -I'm not around this weekend (persuing my other hobby of divingfurygan man wrote:..... Will have a go at fitting at weekend if i'm around, apreciate the nod though
- furygan man
cheers for the offer Tweaker but although i live north of Bradford same village as 'Herbatious' the bikes lives in Leics at my parents, DRider always offers to help (he's not far away in Cov) when i get in a flap about stuff but usually get it sorted somehow.
Just a bit frustrating not being able to work on it until everyother weekend...sure hope it is the battery though
- furygan man
Thank you...you lovely people you!!!
New battery fitted as you'd all recomended, pressed button and boom, fired away
...oh the relief! K & N filter fitted too
Starter relay on order as a recomended, have found location, seems straight forward enough
Thank you again all!!
**DRider- just one thing, when i came to flip the holding bracket in place the recess between the terminals wasn't as wide as it should have been, i took some of the 'spacing' out of the bottom and it is sort of held in place now, was it the same with yours or have they sent me the wrong model?
Re: Thank you...you lovely people you!!!
The shape of the top of the YTX and YTZ batteries is different. As I said in the thread where I described fitting my YTZ, I had to make up spacers for both top and bottom - the top one just fills the top clamp in the area that the YTX battery would fill.furygan man wrote: **DRider- just one thing, when i came to flip the holding bracket in place the recess between the terminals wasn't as wide as it should have been, i took some of the 'spacing' out of the bottom and it is sort of held in place now, was it the same with yours or have they sent me the wrong model?
for spacers, read "bits of wood I had lying around that I cut to length"
- furygan man
