Falco running on one cylinder
IF you do have to whip the spark plugs, the process is as follows:
1. Remove the two bolts holding the front of the tank in place. (8mm). lift the tank and find a suitable propping up tool.
2. Remove the 7 bolts holding the airbox cover on. (7mm), remove the airbox cover and the air filter.
3. remove the six 4mm allen bolts around the throttle bodies. Remove the airbox.
4. Remove the rubbery plastic piece connecting the front air intakes.
Now you should have acces to all 4 spark plugs. asdsembly is the reverse of the instructions above (weirdly enough ;))
Dale
Dale
Well the process to start a completely flooded motor (both pots) is to hold the throttle wide open and crank it - very quickly it clears and fires up.
I've shut the engine down and fired up again in this way when I've had this single pot running and sometimes it's done the trick - though not as reliably as when flooded on both.
- Falcopops
Diag 1 only menas your Throttle position sensor is a bit off in the fully closed position. Notyhing to worry about and I'd be happy to ignore this. Certaily for the moment and indefinitely really.
The pic of the wires under the seat confuded me a bit until I figures the wires with the choc blocks on must be the derestric wire snip. I'd tape them up well just to be sure they don't short out.
Clearly you've figures the others are the diag wires.
I had this problem once and only once, it was a loose chip in ECU, now if the ECU hasn't been opened (the lables are not split) then that's unlikely to be the case.
I'd imagine that the pot that isn't firing will have very fouled plugs by now and If your taking them out spend the money (I know that'll be hard for a fellow Scot) on Irridium plugs and then you can forget about them 'till Nessie is found.
Plug caps and leads have been known to work loose as have plugs, but that makes an almighty racket, trust me, I know!
You could try pulling the low tension wires off the coils to find the pot that isn't running.
Good luck and be sure to tell us the cause and solution.
Know what you mean about tight Scots but I'm from Ullapool and we're pretty generous on the west coast - we only sell our aunties
Yep, a new set of plugs is worth it if it comes down to it.
Thanks y'all for the advice. I'll review in the cold light of Bran Flakes and hopefully get it together
The bike rocks otherwise BTW yet methinks a PC3 is in order - the Tiller had a PC2 on board which I got reset on a dyno near Cromarty ( http://www.hmdtuning.co.uk/ ) and on the basis of those results I reckon there's a lot of throttle response and a few more BHP to be squeezed out yet....
Pleased to be dissuaded otherwise.. (can I remap the OEM chip with a laptop and cable???)
Martin
Martin
- back_marker
Ran the engine today and lifted the tank and it's the front cylinder that ain't firing. Pulled the HT leads off the rear plugs just to be sure.
IT WOULD HAVE TO BE THE FRONT ONE!!!
How on earth do I get to the plugs??? Looks like I'll need to remove the airbox and even then it looks awfully tight.
Aaargh!!
Aaargh!!
Two wheels invariably better
- anzacinexile
Finally, got around to whipping the airbox off and removing the front cylinder plugs. Thanks for the advice all and yes, it was easy.
And am I glad I did! Let's just say the plugs were due for renewal and any doubts I had about being excessive in ordering 4 irridium plugs were rapidly dispelled! Quite a bit of grit also lying in the plug socket so hopefully I managed to clear it all out before lifting the plugs out...
Now all I need is the plugs from Evil-bay to arrive (4 x NGK iiridium for £26 for postage which is pretty good) and we're set to boogy.
