spew wrote:My commute is through London and even though I've changed the clutch slave cylinder I still find my hand and wrist hurts as I have to ride the heavy clutch too much.
One other thing - have you made sure that the angle of the clutch lever is correct? With mine, as delivered, the angle of the clutch lever was such that the lever was pointing pretty much straight ahead.
To my mind the clutch lever should be set such that when sat on the bike, in the normal operating position, there should be a straight line able to be drawn through your forearm, hand and fingers when you have your hand resting on the clutch lever. If your hand is canted up at the wrist, even by a small amount, it makes use of the clutch much harder and will certainly cause pain in town. In other words you need a 'straight pull' on the clutch to avoid wrist pain. My levers are set at about 30 degrees below horizontal.
The same should also be true of the brake lever, but poor setting of the angle doesn't normally result in wrist pain. I know that with one of the controls (I think it was the clutch side), I had to dismantle the switchgear, drill out the pip that keys into a hole in the bar tube and then move the switchgear and lever to a point where i could rotate the lever to a comfortable position. As standard, the ergonomics of the clutch lever and switchgear is very poor, IMHO.
