MPL clutch slave cylinders - what mods are required?
barking frog
#16 Post by barking frog » Sat Mar 21, 2009 10:00 am
I fitted a EVO slave cylinder and the sprocket cover fitted without any mods.
I also fitted a bleed bolt to the master cylinder and had no problems bleeding the system
in the normal way, took about 10 minuets.
"Cheer up, things could be worse" somebody once told me. So I cheered up, and sure enough, things got worse.
Steve_P
#17 Post by Steve_P » Sun Mar 22, 2009 6:54 pm
barking frog wrote:I fitted a EVO slave cylinder and the sprocket cover fitted without any mods.
glad thats easy, mine arrived in the post a couple of weeks ago, so need to get out to the garage and fit it this week
#18 Post by mangocrazy » Sun Mar 22, 2009 9:55 pm
barking frog wrote:in the normal way, took about 10 minuets.
I believe a minuet takes a similar time to the classic pop song - about 3 of our earth minutes.
So it took you about half an hour to bleed your clutch, then?
#19 Post by D-Rider » Sun Mar 22, 2009 10:23 pm
That's how cultured we are in the Coventry area - we even time mechanical maintenance by the duration of songs and dances.
...... sometimes our mechanical maintenance turns into a bit of a song and a dance .....
#20 Post by Fausto » Mon Mar 23, 2009 3:26 pm
Wow! Cultured and Coventry in the same sentence :smt003
#21 Post by Aladinsaneuk » Mon Mar 23, 2009 3:53 pm
Some one mention yoghurt?
