Falco may have to go
#16 Post by Aladinsaneuk » Mon Oct 20, 2008 9:43 pm
perhaps tyaking time to look at the posts may help? as in look at what others have done - your engineers should find it easy
#17 Post by D-Rider » Mon Oct 20, 2008 10:16 pm
mangocrazy wrote: That was the sequence of jobs that gave all my engineering firms the heeby-jeebies. I imagine finding an M10 x 1.25 nut and then getting it correctly centred would be 'interesting'... Saves cannibalising the original Falco stand, though.
That was easy .... the nut and bolt that comes with the Gixer stand is the same thread as the Falcos (if memory serves correct). That nut can be welded to the Gixer stand leaving the Falco one to be used as a locknut.
Not sure how easy it was to align - a mate did it for me.
The alternative that has been done is to fill the hole with weld, drill it out and tap it.
mangocrazy wrote:
As a matter of interest would it be possible to heat up a cast stand like the GSXR one to red-hot with a welding torch and bend the leg a touch? And would that affect the strength of the piece?
So why would you want to do this - the Gixer one is perfect apart from needing to modify the mounting.
#18 Post by mangocrazy » Tue Oct 21, 2008 9:08 am
Aladinsaneuk wrote:perhaps tyaking time to look at the posts may help? as in look at what others have done - your engineers should find it easy
With respect, I've spent quite a few hours trawling through the forums trying to get chapter and verse on this. I've had a go and the results haven't been quite what I wanted. I'm now trying to make sure that if/when I try a second time that I've got all bases covered.
#19 Post by mangocrazy » Tue Oct 21, 2008 9:17 am
D-Rider wrote:The alternative that has been done is to fill the hole with weld, drill it out and tap it.
The engineering firms I approached were very sniffy about this approach, saying that weld is brittle and it's not advisable to drill & tap it. I'm only passing on what they say, y'unnerstand...
mangocrazy wrote: As a matter of interest would it be possible to heat up a cast stand like the GSXR one to red-hot with a welding torch and bend the leg a touch? And would that affect the strength of the piece?
D-Rider wrote:So why would you want to do this - the Gixer one is perfect apart from needing to modify the mounting.
As I mentioned in an earlier post; When I offered it up to the bike it looked great except that the stand foot fouls one of the exhaust springs when retracted. I was thinking that I could get the stand bent out a couple of degrees to avoid fouling the exhaust spring. So, does anybody know whether heating cast iron up to red heat will weaken it in any way?
#20 Post by Falcopops » Tue Oct 21, 2008 12:43 pm
Mine did this at first, so I got a piece of metal welded to the stand to stop it folding up quite so far
robertorolfo
#21 Post by robertorolfo » Tue Oct 21, 2008 1:03 pm
If I get a chance this week, I'll take a picture of my stand and post it up on here.
It is a huge mess of a thing, but it works perfectly and doesn't hinder ground clearance. I remember when I was looking at the bike in the dealership (I had no idea about the stand issues) I was thinking that it was a mess, and that it must have been some sort of crash repair or something. But the bike was so cheap I dind't care. Worked out very well though.
Falcoholic
#22 Post by Falcoholic » Tue Oct 21, 2008 1:45 pm
Falcopops wrote:Mine did this at first, so I got a piece of metal welded to the stand to stop it folding up quite so far
Can't imagine from whom you stole that idea.
The Delicate Sound of Thunder
#23 Post by Fausto » Tue Oct 21, 2008 3:28 pm
I believe most of this info is in the archived threads... did you search those?
#24 Post by mangocrazy » Tue Oct 21, 2008 4:26 pm
I've read references to archived threads, but not been aware of how to get at them. Can you give me the URL? Thanks in advance...
#25 Post by Fausto » Tue Oct 21, 2008 4:52 pm
Simple... just go to the last sticky thread on the Falco forum and clicky da linky. :smt001
It's called the ARS Archive and is I believe all the Forum chat we had going on before ARS was absorbed into this site.
#26 Post by mangocrazy » Tue Oct 21, 2008 6:07 pm
Fausto wrote:Simple... just go to the last sticky thread on the Falco forum and clicky da linky. :smt001
:smt053 :smt053 :smt053 Gawd - how stupid do I feel...
robertorolfo
#27 Post by robertorolfo » Wed Oct 22, 2008 8:36 am
Here is that pic I promised. Sorry for the lousy quality, I snapped it really quick before going to work (the cigs on the ground are not mine, they were just lying in the street there).
As you can see, they stuck a huge piece on there, but like I said, it works very well. It folds up nicely and I've never had clearance issues with it (unlike the exhause).
Since I bought it used like that, I really have no idea what it is. Actually, can anyone tell me if it is a Falco leg with an attachment, or a leg off another bike?
#28 Post by Aladinsaneuk » Wed Oct 22, 2008 10:02 am
falco leg
Firestarter
Twisted Firestarter
#29 Post by Firestarter » Wed Oct 22, 2008 11:58 am
Aladinsaneuk wrote:falco leg
....modified with scaffold-pole re-inforcement, by the look of it.
Not sure why anyone would do that, unless it was a bodge repair for some reason - on the standard stand, the foot bar is quite accessible, not sure what this would add apart from being longer (by the look of it) and sturdier (which I don't think it needs)
Falcoholic
#30 Post by Falcoholic » Wed Oct 22, 2008 2:22 pm
Quality bit of welding there too.
