I'm Falco clueless!
Pan
#16 Post by Pan » Wed Sep 05, 2018 9:57 pm
For some reason I had second thoughts on the bike I was buying and backed out, not exactly sure why but just wasn’t as keen as I felt I should be. I have however found another one though, a European import but will I have to swap the headlight for a uk one and I believe that can the clocks be switched to mph?
Cheers,
Mark
#17 Post by blinkey501 » Thu Sep 06, 2018 5:32 pm
If you check out jeanlucridehards profile I think he's selling His?
It's a nice bike.
JeanLucRidehard
#18 Post by JeanLucRidehard » Thu Sep 06, 2018 8:10 pm
Ive DM’d you pan
Cheers JLR
2107 Africa Twin, Falco purchased........Rebuild complete .....Rossi 2 the fastest, Revealed.......................
Pan
#19 Post by Pan » Thu Sep 06, 2018 8:23 pm
Replied :0)
JeanLucRidehard
#20 Post by JeanLucRidehard » Thu Sep 06, 2018 8:25 pm
:smt006
Pan
#21 Post by Pan » Thu Sep 06, 2018 8:39 pm
Far too nice to tuonoise I’m afraid.
Mark
JeanLucRidehard
#22 Post by JeanLucRidehard » Thu Sep 06, 2018 8:41 pm
Thanks Pan
She’s not a bad old girl for her age, happy hunting my friend :smt006
Pan
#23 Post by Pan » Fri Sep 07, 2018 1:20 pm
Right people, bike now secured and deposit paid. Due to my work pattern and the seller going abroad I’ll collect it at the end of the month :0). It’s an Italian import, completely standard, 40,000km but I think it will need a uk headlight?
Mark
Pan
#24 Post by Pan » Fri Sep 07, 2018 1:22 pm
Mark
#25 Post by D-Rider » Fri Sep 07, 2018 1:49 pm
Pan wrote:Right people, bike now secured and deposit paid. Due to my work pattern and the seller going abroad I’ll collect it at the end of the month :0). It’s an Italian import, completely standard, 40,000km but I think it will need a uk headlight?
Mark
Hard to say regarding the headlight.
Before we realised that Aprilia had fitted a number of UK bikes with European headlights (which they changed over for free), I don't recall anybody having problems at MOT time.
I think the beam pattern is not that severe.
However, MOT tests have got tighter so maybe this would be picked up these days.
I guess it's better to swap it if you can.
#26 Post by fatboy » Fri Sep 07, 2018 3:23 pm
Pan wrote:For some reason I had second thoughts on the bike I was buying and backed out, not exactly sure why but just wasn’t as keen as I felt I should be. I have however found another one though, a European import but will I have to swap the headlight for a uk one and I believe that can the clocks be switched to mph?
Cheers,
Mark
Every time the battery is disconnected the dash display will revert to factory settings, which is kph and a 6,500 rpm limit,sometimes it just does it anyway !
Easy to sort,
kph to mph, push and hold button A until mph flashes, then push button B to confirm.
To change rpm limit, turn ignition on, the needle will rise to the set limit then fall to 0, push and hold buttonn C until chosen figure is achieved, 9,500 is good.
When you have set mph, switch off, then set rpm, switch off,then on again, all should be good
Pan
#27 Post by Pan » Fri Sep 07, 2018 3:31 pm
Thanks for the info that’s really useful, I’ve a lot to learn!
Mark
#28 Post by fatboy » Fri Sep 07, 2018 5:03 pm
No worries mate, we all have to start some where !
If you never ask the answer will always be NO.
Really good crowd on here, tons of know how, all for free ! (Well almost free, it may cost a pint or two in the virtual bar and there may be an element of good natured pisstaking ).
Now you can congratulate yourself on having refined choice in bikes :smt004
#29 Post by mangocrazy » Fri Sep 07, 2018 8:25 pm
For any new Falco owner, this site is a REALLY useful resource - downloadable workshop manual in searchable PDF/OCR format, cheat sheet to tell you how to use and abuse the buttons on the controls, plus lots of other stuff:
Pan
#30 Post by Pan » Sat Sep 08, 2018 5:48 pm
Fantastic, cheers!
Mark
