Thanks everyone for the diag and advice. Wanyo when I get this sorted we should meet up for ride and thanks for asking your mate about the engine. I couldn't get onto the computer last night but having read the responses think that it may not all be over for the engine, I need to get it back home to sort it out which will happen on the weekend. Just need to get hold of a van or trailer or push it. A mate of mine is lending me a bike so picking up an XJ1300 tonight - should be fun.
What was the temperature gauge showing when all this happened? If you had seized the engine there should have been major heat issues at the same time; conditions that result in seizures develop a large amount of heat. They also normally make a very nasty noise and lock the rear wheel - at least they did when I rode two-strokes.
Temp was about 85c when I first stopped and the same the second time. It didn't come to a sudden stop - it just lost power and when i pulled in the clutch it cut out.
So, you put in 3.2 litres. Did you measure how much came out? if so, what was it?
I know it's poor practice but I was only checking amount of oil out of the container I will measure exactly what is left in there, current reading about .8l on the bottle. I know that's not really a good gauge as the oil company's may over fill their bottles.
I would have thought too much oil would burst a seal before the big end went. Are there any oil leaks?
No no oil leaks at all.
Have you actually checked to see if it is siezed? See Mango's reply below for the best way to check if it is siezed.
I did go back in the car and try pushing it in 6th gear but it was a half arsed attempt at about 11pm so wasn't in the right frame of mind. There seemed to be a little movement.
Not sure how too much oil would cause the engine to seize, unless it somehow buggered up the oil pump (possibly whipped into a foam by the crankshaft? (not on a dry sump like the v990 though)), effectively starving the engine of oil. Pulling the valve cover off one of the cylinders would be a good indication of oil starvation - the cams will be scorched.
Oil Pump failure was my mates thoughts so I will certainly take the valve cover off to see if cams are scorched.
If you take the plugs out (2 on each cylinder, remember), put the bike in 1st gear and you can't push it, it may well be seized.
This will be my first check.
Could this be oil pump failure, the motor suffering from hydraulic lock up because the pump didn't scavenge ?
Is there anything that would either stop oil getting to the pump or for some reason knacker the oil pump. All was good before I changed the oil.
thanks again for help I will update when I get time to examine the bike in more detail on the weekend, cheers Matt
