tyre deflection
wayno
#16 Post by wayno » Tue Jul 29, 2014 7:33 am
As the rub mark has a 'start' it may simple be that you hit a bit on debris in the road whilst cranked over.
If you have checked that nothing it rubbing, the next stop is to check the pressures, after that have a quick check to make sure your wheel is aligned and tight, it may not be rubbing in the garage but under load (and leant over) it may be shifting.
I would ask how the handling is, but it must be pretty sweet if you're scrubbing to the edge of a set of Pirelli's.
zoidberg
#17 Post by zoidberg » Tue Jul 29, 2014 8:50 am
still haven't had chance to check pressures (busy with work :smt012 ).
the mark is around the entire circumference on both sides of the tyre. I know the wheel is tight as I torqued it up. I only ever take loose wheels to get tyres put on.
i'll check the pressures and get back, and yeah the handing is fine :smt002
Firestarter
Twisted Firestarter
#18 Post by Firestarter » Tue Jul 29, 2014 1:20 pm
Have a word with the tyre fitter, see if it's possible that they've done something during fitting
wayno
#19 Post by wayno » Tue Jul 29, 2014 1:27 pm
Seems to me the problem is excessive corner speed :)
Solution
A) Slow down
B) Stop looking at the rear tyre :)
zoidberg
#20 Post by zoidberg » Tue Jul 29, 2014 1:31 pm
haha, They may have been simlar marks on my old tyres. I never looked i only noticed them after coming home after the first run to see if they were scrubbed in properly.
Flatlander has them now, and i do still have some pics on the for sale thread. I'll have a look at them now.
zoidberg
#21 Post by zoidberg » Sat Aug 02, 2014 7:15 pm
Pressures are fine. I'll go with wayno option b
