possible sprag failure
#16 Post by fatboy » Wed Jun 25, 2014 6:22 pm
Powerhouse 0114 2351010
The seal kit you need is B44
Contains 32 seals, copper washers and bleed nipples, this will do both calipers, cost around 48 golden nuggetts
robbier6
#17 Post by robbier6 » Wed Jun 25, 2014 6:52 pm
cheers fatboy....
right here's what I've tried tonight....
tightened battery terminals..they were tight and greased
checked cleaned and replaced fuses.
had jump leads on car to bike to give battery a boost with car running...nothing..tightened connections on the solenoid nothing.
still all I have is a clicking solenoid and a whirring fuel pump, you can hear the pump prime when the ignition is flicked on.
any further ideas? as I'm stumped....thought it might be the power commander playing up?
#18 Post by Aladinsaneuk » Wed Jun 25, 2014 7:04 pm
Screwdriver across the starter solenoid......
robbier6
#19 Post by robbier6 » Wed Jun 25, 2014 7:16 pm
success....screwdriver across the terminals of the solenoid and she spins up...looks like a replacement 'noid?
I'm off to the bar if anybody wants a beer it two?
robbier6
#20 Post by robbier6 » Wed Jun 25, 2014 7:19 pm
#21 Post by Aladinsaneuk » Wed Jun 25, 2014 8:25 pm
Ahem
Much to badgerpubes surprise
I told you ages ago!
Pint of virtual rusty nail
wayno
#22 Post by wayno » Thu Jun 26, 2014 11:26 am
If you're replacing the solenoid, go for the one with a higher current rating, the bike will start that little bit better than standard.
robbier6
#23 Post by robbier6 » Fri Jun 27, 2014 6:59 am
Thanks Wayne, going to go for the 100amp version, think that's what i replaced it with last time, that time it was sticking on and now its not coming on, how bizarre
#24 Post by HowardQ » Sat Jun 28, 2014 8:49 pm
I replaced mine with an uprated 100 amp version (via Scooter Assasins on eBay), you can also get a 150 amp version these days as well.
Somebody will let you know where from, if you need it.
robbier6
#25 Post by robbier6 » Mon Jun 30, 2014 7:58 am
Thanks Howard, i saw the 100amp version on ebay too.. is that version more effect?
#26 Post by D-Rider » Mon Jun 30, 2014 8:34 am
I've been running the scooter assassins one for years now - ever since my original failed.
100A or 150A - it doesn't really matter - either will cope with the current draw from the starter. What is important is to have one with good quality contacts.
robbier6
#27 Post by robbier6 » Tue Jul 01, 2014 12:58 pm
Ordered yesterday from scooter assassins, hoping its delivered today, though more likely tomorrow :smt003
robbier6
#28 Post by robbier6 » Fri Jul 04, 2014 7:58 am
well new solenoid fitted, engine spins up a dream.......
but won't fire! :smt013 or fires and dies. the bike has rene air kit, pc3 set with a map for open airbox and race cans, and fuel cans with baffles in
i'm now thinking coil packs? anybody concur?
Midnight Rider
#29 Post by Dalemac » Fri Jul 04, 2014 9:31 am
robbier6 wrote:well new solenoid fitted, engine spins up a dream.......
Depends if it is getting a good spark! only one way to find out....
Firestarter
Twisted Firestarter
#30 Post by Firestarter » Fri Jul 04, 2014 9:37 am
Tried the full-throttle start? In case it's flooded from all the attempts?
