A bit old school but you can pop the thermo in a pan of water and boil it while having a multimeter attached and a sweetie thermometer to one side - shows at what temperature the switch really closes.
If it doesn't go by 105 C then turn off the hob ... and replace thermo
Cooling fans not coming on
But surely a failed stat would show itself as coolant not getting to temperature (failed open) or temperature rocketing up (failed shut). Either way whether the fans come on after a certain coolant temp has been reached is a different issue, isn't it?
Temperature climbed steadily, as I'd expect, but fans failed to come on when coolant temp was already 102-103 deg C. Normally fans kick in around 95-96 deg C on my bike.
Thats how I always try and approach problems, thankfully it worked for youmangocrazy wrote:Just a quickie - when I checked, one of the connections to the switch had been pulled loose. Reseated it and normal service was resumed.
Which just goes to show, always check the simple stuff first...
