Top yoke identification
Falco Frank
#16 Post by Falco Frank » Sun Aug 04, 2013 7:01 pm
Well done, good bit of lateral thinking!
wannesd
#17 Post by wannesd » Mon Aug 05, 2013 11:15 am
iconic944ss wrote:Wow, nice one Thanks.
I bought a Vapor ages ago for another project but it does not look as good as that.
Never heard of the Futura level gauge mod either, very clever - well done!
Hmm me too - I've acquired a Vapor for another project but I like a look of this one and the others they do. Not too bad a price either. Hmmmm .... stroked beard .....
There's also a DB01R, but it's not suited for aprilia.
DB01R+ has a fuel light, same as in original dash. Just a simple on/off contact. (also a digital fuel meter)
DB01R only has the digital fuel meter, so it can't be wired to the switch. (it can, via a resistor mod, but not really plug and play, and there wouldn't be a range in the gauge, just full / empty.)
I wired every function to the DB01R+:
- Neutral light
- High beam light
- Normal light is indicated by backlight
- Oil pressure
- EOBD light is wired to sidestand switch, as we have no eobd.
- side indicators
- Fuel meter to futura fuel sensor (displaying complete range)
- Fuel light is wired to my circuitboard, indicating when I'm in full power map, or fuel saving map (gabro chip)
and of course rpm and speed.
Like to point out that by careful studying of the wiring diagram (I integrated my circuit board into the bike to take automatic control of some features), I was able to wire the koso completely to the existing wires.
So if you do go for this unit, I can help you out by giving the color codes you need to combine.
#18 Post by D-Rider » Mon Aug 05, 2013 11:20 am
Thanks for the info but if I were to get one it wouldn't be for the Falco.
