zoidberg
#16
by zoidberg » Fri Jul 26, 2013 5:35 pm
Mine is an 01 falco so again an early one. Gonna have look soon.
#17
by fatboy » Fri Jul 26, 2013 5:36 pm
I love kickstarts !
robbier6
#18
by robbier6 » Fri Jul 26, 2013 6:34 pm
I had the same problem...was a starter relay not letting go
#19
by D-Rider » Fri Jul 26, 2013 6:59 pm
wannesd wrote:Aladinsaneuk wrote:I had the exact same symptoms 3 weeks ago.....
The relay stops with ignition off, sticking button carries on with ignition off
You would also have generated an EFI error over 3500 revs...
Sorry, but I've looked at the wiring diagram, a shorting relay will continue with ignition on or off, as it feeds directly from the battery. Sticking starter button is fed by switched 12V, so would stop when ignition is turned off.
That is exactly correct
zoidberg
#20
by zoidberg » Fri Jul 26, 2013 7:40 pm
Starter solenoid terminals have welded themselves together. Hopefully the replacement arrives in the morning.
#21
by fatboy » Sat Jul 27, 2013 3:26 pm
fatboy wrote:I love kickstarts !
That will teach me to be cocky, cleaning up starter motor connections today, turning over really slow and re setting dash to factory settings......
Sorted all that then fucked clutch up
zoidberg
#22
by zoidberg » Sat Jul 27, 2013 3:45 pm
New solenoid and all is well with the world.
