should have bought one years ago
zoidberg
#16 Post by zoidberg » Mon Jul 08, 2013 7:08 pm
it's still on the standard eprom with sl cans so prob won't help matters. i'll decide how far i'm going then order a forza chip.
browny
#17 Post by browny » Mon Jul 08, 2013 7:50 pm
I have fitted s forzaaprilia chip and it has improved low speed smoothnesssmoothness
info I have Blue flame cans with no baffles, kn air filter and the usual derestriction mod
#18 Post by HisNibbs » Mon Jul 08, 2013 7:56 pm
fatboy wrote:
zoidberg wrote:Chatters and feels awful pootling around at low speed.
Slipping the clutch helps.
I only slip the clutch to keep the front on the tarmac, yes sometimes from 2nd to 3rd
A falc does have the poke to do that !
I am confused again.... :smt017
Not about the poke bit as the front is often lifting off the bumps in 3rd even 4th if the road is dropping away. Backing off the throttle a little or a touch of back brake if its rising fast, but slipping the clutch?
I can see that it will disengage drive stopping the wheelie; and the motor will also smack into the rev limiter but then what happens when with a big handful of throttle still on, you try to let it out again? All sounds a little too brutal for me.
