Just about given up.
#16 Post by Kwackerz » Sun May 19, 2013 9:58 pm
See my comment in the other thread. have van.. and can toodle down the A14 sometime en route to doncaster and pick yours up
#17 Post by flatlander » Sun May 19, 2013 10:10 pm
very I think you will find most of us are pretty impressed with the reliability etc. Things I know I've done ... put the tip over sensor in the wrong way up
If its the flooding one of the members or the search will reveal ways round that better than my fumbling words but cleaning and checking the plugs may give a clue.
if the bike is getting power and just not firing then it at least should help narrow things down... sorry if I am not being much help buut was anything changed from when you got the bike ? was there any aftermarket parts that may have been removed and are affecting the running ?
Is there fresh fuel in the bike as old crappy fuel can cause problems so may be worth draining if it is old and refill with fresh
did it have an alrm on it that wasn't removed properly ?
#18 Post by blinkey501 » Mon May 20, 2013 3:44 am
Question 1
Have you removed the air box whilst trying to start the bike?
Question 2
Did your fit your chip to my ECU that I loaned you.
Question 3
Did you smell a strong smell of petrol when you was cranking the bike over from the exhaust.
Question 4
What eprom "chip" have you got fitted to your ECU
Question 5
Did you here the noises you described when you had fitted the ECU I loaned you but not when you had yours fitted.
Just to let you know the ECU I loaned you has the mille chip fitted so it won't be in tune with your set up.
Re fit you ECU to the bike and remove the air box.
Do not turn the fast idle "choke" on, leave it in the off position.
Open the throttle fully (Do not open and close the throttle) and with the tank propped up away from the T/B's try to start the bike.
If you get a good smell of petrol and a back fire from your throttle bodies the engine will be flooding.
The back fire will indicate the bike is trying to start.
If this happens remove your plugs and dry and refit them.
Open the throttle fully and try again. Let us know what happens and the answer to my questions fella :smt023
Finally the noises you describe. I think the bike may be trying to start. Slapping noises?
#19 Post by Kwackerz » Mon May 20, 2013 8:06 am
and dont lean over the throttlebodies when youre doing it....
ROCKOZ
#20 Post by ROCKOZ » Mon May 20, 2013 11:52 am
blinkey501 wrote:Question 1
Have you removed the air box whilst trying to start the bike? Air box removed.Question 2
Did your fit your chip to my ECU that I loaned you. I haven't opened your ECU (surely it should still start with a mille chip)Question 3
Did you smell a strong smell of petrol when you was cranking the bike over from the exhaust. YesQuestion 4
What eprom "chip" have you got fitted to your ECU standard falco chip
Question 5
Did you here the noises you described when you had fitted the ECU I loaned you but not when you had yours fitted. Yes and I didn't try to start it after refitting my ECU
Slapping noises as if something were attached to a the cam as it's spinning round hitting the head on its way round (I know thats not it) - I could take a video but I'm so sick of it I just want it gone.
It's not sparking.
Just bought a Falco :)
Midnight Rider
#21 Post by Dalemac » Mon May 20, 2013 1:16 pm
Question 5
It's not sparking.
If it sounds as though it is at the top of the head it could be a cam chain tensioner. If they have sat for a while then can be a bit rickety until oil builds up again (they are hydraulic chain tensioners after all). I replaced my tensioners not too long again and they make an awful noise until the pressure is where it should be.
If it is not sparking, what have you checked/replaced so far?
Dale
ROCKOZ
#22 Post by ROCKOZ » Mon May 20, 2013 1:29 pm
It feels like I've checked everything.
We checked the pulses of the coils and fuelling using an audio programme on the laptop. That was all fine. I'm just not thinking logically about it at the moment I'm so annoyed.
Midnight Rider
#23 Post by Dalemac » Mon May 20, 2013 1:53 pm
Has the battery been replaced?
It's probably the #1 cause of non-starting falco's. Even if it turns the starter motor, it might not be providing enough power to create a strong spark.
Earlier on in the year i was absolutely convinced that the battery was fine because it would turn over perfectly. But it would not start. Replaced the battery and then it started up instantly.
Dale
Cap'n Puke
#24 Post by Cap'n Puke » Sun Jun 02, 2013 3:37 pm
I was convinced mine had a dodgy starter relay or bad wiring - ended up having to ditch it in a mates garage over the winter as i took a new job abroad. while I was away the 'friend' jumped it of his car battery - well bugger me if it did't start right up. I've since been home, bought an uprated gel battery and she's starting up a beaut at the mo. Morale of the story - never discount a bad battery, even if its cranking over ok.
I've been in the same place as you mate, I've considered breaking it for spares and just breaking it in general, I just have to keep going and hoping it'll come good one day - I have had some very, very good days on it when it all came together and was, well, magical. My bro rode it on one of those days, got home and immediately put his GSXR 1000 K4 up for sale because the Falco made it feel so.... ordinary.
#25 Post by blinkey501 » Sun Jun 02, 2013 3:48 pm
Cap'n Puke wrote:I was convinced mine had a dodgy starter relay or bad wiring - ended up having to ditch it in a mates garage over the winter as i took a new job abroad. while I was away the 'friend' jumped it of his car battery - well bugger me if it did't start right up. I've since been home, bought an uprated gel battery and she's starting up a beaut at the mo. Morale of the story - never discount a bad battery, even if its cranking over ok.
The falco that you are talking about is now running fella :smt003
Cap'n Puke
#26 Post by Cap'n Puke » Sun Jun 02, 2013 4:12 pm
Indeed it is - sent you a mail about stopping by to have some other work sorted...
#27 Post by blinkey501 » Sun Jun 02, 2013 6:29 pm
Cap'n Puke wrote:Indeed it is - sent you a mail about stopping by to have some other work sorted...
I don't have a pm?
#28 Post by fatboy » Sun Jun 02, 2013 6:43 pm
A falc makes everthing else look ordinary !
Not ridden a KTM yet though but find it hard to imagine anything else can ooze the appeal and excitement of a thundering falco !
ROCKOZ
#29 Post by ROCKOZ » Wed Jun 05, 2013 8:21 am
I've ridden a 990 ADV and loved the power delivery...but it's not as nice as the falco.
One thing I prefered though was the position and probably looks... :O
#30 Post by fatboy » Wed Jun 05, 2013 6:34 pm
Falcs are little known, most people have heard of the RSV clan, to put it one way, the Falc is the unexpected full on bonus hardcore porn dvd of the bike world !
As in they do shock a few !
