ideas anyone
#16 Post by flatlander » Wed Apr 10, 2013 4:59 pm
Dalemac wrote:If it's not priming, is the fuel pump relay OK? swap it with the engine kill relay, as they are the same, and try again.
Funnily enough mine is being temperamental at the moment too. It's as if they are all too old and want to give up on life.
Dale
Surely not Alad I always got the impression he was the much younger if not quite so streamlined of the two :smt020
#17 Post by fatboy » Wed Apr 10, 2013 5:41 pm
Ive spent a lot of time looking at the fuel supply wiring !
Dont recall seeeing any unused connector on the relay side.
The pump wiring is blue with green trace, as is most of the fuel supply wiring.
Check you have voltage to the pump relay. If you got power there, disconnect the block connector from main loom to tank ( 3 wires,rectangular connector ) see if you have power from the relay.
If power from the connector, suspect pump or pump wiring.
Hope this is some use
edit. dyslexic writing
#18 Post by Aladinsaneuk » Mon Apr 15, 2013 6:02 am
well, to update folk - nothing doing - have checked fuses and relays, checked for loose connections etc - so, i think the next thing is too check the actual fuel pump itself.... I rather fear that I may have to cancel some of the meets I was due to attend soon :(
#19 Post by flatlander » Mon Apr 15, 2013 8:34 am
Well if you found out quickly you may know someone who has one on eBay this week along with some damned fine luggage :)
#20 Post by Aladinsaneuk » Mon Apr 15, 2013 5:08 pm
Right - fuel pump primes with power direct to it. Swopped relays over - still no priming of fuel pump.....
#21 Post by Kwackerz » Mon Apr 15, 2013 5:13 pm
Out with the multimeter then, eh..
#22 Post by Aladinsaneuk » Mon Apr 15, 2013 5:15 pm
I may have to call in the Hobbit Air Service .... I am at my limit with electrickery.....
Midnight Rider
#23 Post by Dalemac » Mon Apr 15, 2013 5:17 pm
So, is the relay being supplied with power?
#24 Post by fatboy » Mon Apr 15, 2013 6:53 pm
This is so similar to my long term woes. Everytime I removed pump from tank and bench tested it it worked as I was running a direct earth to it.
The fuel pump was the culprit,got it working by wiring an independant earth to it, but in the end, that failed to make it work.
Griff found the problem and said you would never find it with out diagnostics.
Get a new fuel pump and see how you go ( £50 ish from breaker )
EDIT the problem was the pumps internal earth breaking down so could not work when coupled to loom earth
#25 Post by mangocrazy » Mon Apr 15, 2013 8:32 pm
fatboy wrote:EDIT the problem was the pumps internal earth breaking down so could not work when coupled to loom earth
Gulp - now you mention it, I remember reading about the same thing happening to someone on the AF1 forum - caused them massive headaches as well. Can you actually get at the faulty wiring and repair it, or is it a throw away and fit replacement jobbie?
#26 Post by flatlander » Mon Apr 15, 2013 10:17 pm
sits quietly gloating that he just opened one of the many bags that have been waiting to be sorted and found ... oh goodness not ANOTHER spare brand new fuel pump!!! :smt003
#27 Post by Aladinsaneuk » Tue Apr 16, 2013 5:45 am
damn glad i spoke to you yesterday geoff.....
notice i am being polite... ish :)
#28 Post by flatlander » Tue Apr 16, 2013 8:51 am
if you look in the tyres folder at least you could be of some use there :smt003
#29 Post by DavShill » Tue Apr 16, 2013 1:03 pm
Andy - any joy fixing your non-starter?
#30 Post by flatlander » Tue Apr 16, 2013 2:54 pm
to be fair to Alad at least he hasn't had to call green flag this time :smt003 or do you not have homestart?
god will punish me i know when I go out to the garage later but for once I can just enjoy it not being me :smt005
