Airbox mod for skint
sabestian
#16 Post by sabestian » Thu Apr 26, 2007 2:32 pm
I think I'll just keep the map for you (in case you wanted to swap it for The Template of your airbox mod plate) :smt002 But thanks for generous offer. :smt003
paddyz1
#17 Post by paddyz1 » Thu Apr 26, 2007 3:30 pm
sabestian wrote:I think I'll just keep the map for you (in case you wanted to swap it for The Template of your airbox mod plate) :smt002 But thanks for generous offer. :smt003
When I get the correct material I will send you a base :smt002
sabestian
#18 Post by sabestian » Thu Apr 26, 2007 3:52 pm
paddyz1 wrote: When I get the correct material I will send you a base :smt002
Is there anything wrong with the one you carved recently?
paddyz1
#19 Post by paddyz1 » Thu Apr 26, 2007 4:37 pm
No that one is fine. The other material was a softer plastic. Whenever i cut, drilled or recessed a hole, the heat of the cutting tool just fused it back together making an unworkable mess. The stuff I used for mine is a very hard plastic which would snap before it bends. I brought it from a bike show (Stafford show) There may be the same type of stall at the thundersprint next month. I will buy as much as I can if it is there.
