#16
by D-Rider » Mon Nov 26, 2012 9:50 am
anzacinexile wrote:Falcopops wrote:Impressive, but how the hell did that work?
More info required
Improvised Ezy-Out, like it
Indeed ... but without the left-hand-thread of an easy-out .... back to Falcopoops question.
..... and Eddie certainly wins this month's bravery competition!
eddievtwin
#17
by eddievtwin » Mon Nov 26, 2012 12:40 pm
Well I used my trusty dremel too make a slot in the screw too undo it but because all the edges of the jet had mushroomed out , it wouldnt come out , and I hate using extractors ( if they snap off your knackered) . So I used a soft self tapping screw just to get a grip on it , and hey presto all done new jet in no leaks , now wasnt that easy like hell it was. Why is it allways the bolt or screw with the worse access to it that gives you problems ???
Eddie
#18
by Viking » Mon Nov 26, 2012 11:50 pm
eddievtwin wrote:Why is it allways the bolt or screw with the worse access to it that gives you problems ???
Because life would be too easy, otherwise!
