The Gabro chip
#16 Post by D-Rider » Wed Aug 22, 2012 3:25 pm
Tried for ages to get some proper info on Dr Rossi but it's never forthcoming. Still not established whether it just remaps fuel or alters ignition timing too.
Timlin
#17 Post by Timlin » Wed Aug 22, 2012 3:27 pm
I've just fitted a Gabro chip in mine and i can't believe how much better it is over the standard chip, bargain at 75 euros too .
#18 Post by flatlander » Wed Aug 22, 2012 5:50 pm
D-Rider wrote:Tried for ages to get some proper info on Dr Rossi but it's never forthcoming. Still not established whether it just remaps fuel or alters ignition timing too.
well if you want you can check mine
#19 Post by D-Rider » Wed Aug 22, 2012 8:48 pm
..... so ...... pray tell ..... does it alter the ignition timing map?
Is it as good as it's cracked up to be in some quarters?
#20 Post by flatlander » Wed Aug 22, 2012 9:47 pm
no idea just have it in a case need something to plug it into to read it I guess which I dont have
#21 Post by D-Rider » Thu Aug 23, 2012 8:45 pm
I'll have to have a nose round the lab at work to see if we've still got an appropriate reader.
That said, I've no idea of the address map of the eprom so we'll get a load of numbers but may have little understanding of what they all mean .........
rick
#22 Post by rick » Fri Aug 24, 2012 7:35 am
when you say over fuel, just running rich? what are the negatives of this, apart from the obvious?
and where can I get hold of the gabro chip? assuming he'll ship to nz!
#23 Post by D-Rider » Fri Aug 24, 2012 8:00 am
rick wrote:when you say over fuel, just running rich? what are the negatives of this, apart from the obvious?
Yes running rich.
Uses more fuel, carbon deposits, may not perform as well as it could.
Gabro is a member of the AF1 forum and he can be contacted by PM on there. I dare say an email address exists but I don't have it.
Pretty sure he'll ship almost anywhere.
#24 Post by Kwackerz » Fri Aug 24, 2012 3:20 pm
malarone@ gmail.com (without the spaces)
wayofthedarkhand
#25 Post by wayofthedarkhand » Sat Aug 25, 2012 9:07 am
Arrived this morning
#26 Post by Aladinsaneuk » Sat Aug 25, 2012 6:14 pm
fitted this afternoon
#27 Post by fatboy » Sat Aug 25, 2012 6:19 pm
Another negative of 'running rich' is the possibility petrol breaking down the oil film on the piston,rings and cylinder liner.
To cause that kind of wear,you would have to be a bit thick not to notice it aint running right
rick
#28 Post by rick » Sun Aug 26, 2012 7:15 am
I've emailed Gabro... looking forward to seeing what he can do... and then comparing it with standard and factory pro :)
#29 Post by flatlander » Mon Sep 03, 2012 9:48 am
Right did some asking and Dr Rossi will apparently write custom maps also. As on he will write for advance for larger throttle bodies etc.
Whilst on the subject any precautions when changing chips or just open her up and swap her out ?
