NWS hugger and 190/55 rear tyre
To be honest, I did consider a CF hugger, but decided on the GRP one as I wanted to have it painted and colour matched to the front mudguard/tank.
It does seem a waste to buy a CF hugger only to have it painted...
So - does anyone have experience of a Skidmarx hugger with a 190/55? I guess they're the only other option?
Gratuitouse 'rear end' shots for mango.
Remember as the wheel spins the tyre is going to grow a bit...but I don't think it is actualy making contact with the hugger. Oh and hugger matches the CF front mudguard, maybe treat myself one day to a cf belly pan.
Bye the bye the 190/55 does give a lot more lean angle before running off the edge of the tyre. The rear and front profiles just about match now. Feels good just need some dry roads and a little more confidence.
Cheers Keith - much appreciated. It's still fairly adjacent, but not as bad as my GRP hugger. I do wonder whether different tyre makes will have different clearence (or lack of it).
Agree about the 190/55 profile. It felt really good and confidence-inspiring. I wouldn't want to swap back to a 180/55, even after only having covered about 70 miles with the 190/55.
sorry if this is a diversion from the original topic, Im about to re launch my falco afterover 2 years of legal shit with DVLA'
I have no hugger fitted,will be fitting new hoops along with Sachs white spring shock and shiney stuff,so before I order my tyres Im guessing buy a 190 rear rather than 180 ? ?
Ordering new rubber on thurs, payday
Standard fitment is 180/55 and there is not much wrong with it. It is undersize on the rims and probably has a flatter profile than a /55 should be because of that. The normal alternative option is a 190/50 which provides an even flatter profile.
The 190/55 we are talking about here is a more expensive tyre and not standard or manufacture recomended fitment. There may be a need to tell your insurance company etc. It is taller and wider and a very close fit but does provide more contact patch at high angles of lean. If you have any sign of chicken strips on the 180/55 or 190/50 there is no point fitting this size as the contact patch is probably smaller at the lean angles being used.
Good news for pete thenHisNibbs wrote:Standard fitment is 180/55 and there is not much wrong with it. It is undersize on the rims and probably has a flatter profile than a /55 should be because of that. The normal alternative option is a 190/50 which provides an even flatter profile.
Don't forget it is not standard fitment so maybe just for the sake of completeness......blinkey501 wrote:Good news for pete thenHisNibbs wrote:Standard fitment is 180/55 and there is not much wrong with it. It is undersize on the rims and probably has a flatter profile than a /55 should be because of that. The normal alternative option is a 190/50 which provides an even flatter profile.
